Originally Posted by scott33b Thannks for the quick reply.
Was looking at this lens on ebay as a first lens, until I get the hang of the camera.
CANON EF 80 - 200mm F/4.5 - 5.6 11 LENS
Also was thinking of buying the kit lens second hand. I see them for about £25.
Is this a good start?
cheers |
I wouldn't recommend this as a first lens, this would leva eyou very restricted. What you really want is a good or entry level walkaround lens. The 18-55mm, kit lenses can be picked up fairly cheap, but you will want to change it pretty quickly. Other good candidates would be the sigma 17-70mm, sigma 17-50mm. But these tend to be alot pricier coming in at around £200.
But as you can see, you would be better getting a lens that covers the lower zoom range. But as already said, it depends on what you like to photo.
Good beginner option would be the kit lens (Canon 18-55mm) and the Tamron 55-200mm, these are cheap and give you some options.
