Re: HELP ! Canon 300D Zoom Browser Disc
You should not need Zoom browser to actually download images
You should just get a USB compact flash card reader, pop the CF card in it and copy away by drag and drop
If you want to do remote capture and control the camera from the computer ( including capturing direct to a PC or laptop HDD
) then you would benefit from connecting up the camera to PC otherwise all you need is the card reader
Using has its merits and you can review the image immediately on a wider screen ( than the 300Ds) small LCD
If you do want the Disc though I could send you one from the 30D , 350 or 400D which simply contain the window drivers( WIA) ( which you do need if you must use the camera) and the EOS utility,
Zoom browser and DPP
Both of which have been updated several versions since the original discs were made
Just pop a PM with your address
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
