Originally Posted by Rookies Ok Folks
I dont really fancy spending £300 for a macro lens, but if have to I might have to but would involve alot of nagging...
What other ways is there to take nice macro shoots.
Andrew |
Firstly, the Tamron 90mm macro goes for £199.99 at Onestop Digital, and the Sigma 105mm macro goes for about £20 more. Both are very good macro lenses.
The other alternatives are:
Get a set of extension tubes (Kenko or Jessops for Canon) and use a standard lens.
A Diopter that screws onto the lens like a filter (Canon 500D)
A reversing ring to mount a lens reversed on the camera's body
The results will not be as good as a dedicated macro lens, but might be acceptable to start off with.
Mike
