07-04-2008, 3:53 PM
#1 (permalink)
| | Prominent Member
Join Date: Oct 2006 Location: Sunny Stafford (UK) Halo 3 Rank: Brigadier [46]
Thanks: Gave 1,945, Got 1,030 | Where to buy Circular Polarizing Filter and/or ND grads??
Inspired by the 'Skye Photos' thread, full of amazing landscapes with dramatic skys and silky waterfalls, and with my birthday on the horizon, I would like to buy a Polarizing filter and [budget dependent] a/some ND grads as well [I note allymac makes good use of his ND8].
Anyone got any pointers as to the best place [online preferred] to get these sorts of things?? And any particular brand recommendations would also be greatly appreciated
__________________ Setup: Sharp LC32GD8E, Toshiba EP30 HD-DVD, XBox 360 (60GB), Sony Alpha 200, Turtle Beach X1 Favourite DVDs: Black Hawk Down, Dark Knight, 300 (HD), Ronin, Bourne Trilogy (HD), Se7en Currently Playing: Modern Warfare 2, Halo 3: ODST, Halo 3, Borderlands My flickr photo gallery |
07-04-2008, 4:36 PM
#2 (permalink)
| | Member
Thanks: Gave 758, Got 194 | Re: Where to buy Circular Polarizing Filter and/or ND grads??
For the Polarizer I'd go with Hoya here
If it's Cokin P Grads your after then 7dayshop do them here
Hoya ND8's are worth a look on ebay aswell here |
07-04-2008, 5:31 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 472, Got 430 | Re: Where to buy Circular Polarizing Filter and/or ND grads?? Quote:
Originally Posted by xSP4RT4N L4Wx a/some ND grads as well [I note allymac makes good use of his ND8]. | Thanks but I don't actually own any grads. Make sure you don't get confused between a solid ND which is of continuous darkness all over and its only use is to allow for longer shutter speed, and a graduated ND which has a variant darkness. I emulate GND's in photoshop by bracketing my images.
I think I bought my CPL (Hoya Pro1) and my Hoya ND8 off of ebay.
__________________ .......My flickr....... Canon - 40D | 400D | 10-22 | 17-55 F2.8 IS | 50 1.4 | 70-200 F2.8L IS | 100 Macro | 430EX | Manfrotto 055MF3 + 804RC2 | Velbon ULTRA LUX i F | Tamrac Expedition 8 | Crumpler Messenger Boy 7500 |
08-04-2008, 1:26 PM
#4 (permalink)
| | Prominent Member
Thanks: Gave 293, Got 898 | Re: Where to buy Circular Polarizing Filter and/or ND grads??
Warehouse Express is a good spot for filters of all types.
Note also that some significant post processing was involved in many of the Skye shots, usually achieved by blending of 3-5 bracketed exposures in my case.
08-04-2008, 1:41 PM
#5 (permalink)
| | Prominent Member
Thanks: Gave 1,945, Got 1,030 | Re: Where to buy Circular Polarizing Filter and/or ND grads?? Quote:
Originally Posted by Tobers Warehouse Express is a good spot for filters of all types.
Note also that some significant post processing was involved in many of the Skye shots, usually achieved by blending of 3-5 bracketed exposures in my case. | Thanks Tobers......post processing is another area where I'd like to spend some time and improve greatly as well.....
09-04-2008, 6:15 PM
#6 (permalink)
| | Member
Thanks: Gave 74, Got 64 | Re: Where to buy Circular Polarizing Filter and/or ND grads??
Are Hoya polarizers the ones to go for? £25-40 seems quite high when there are others for around £10. Do you get what you pay for?
09-04-2008, 6:34 PM
#7 (permalink)
| | Veteran Member
Thanks: Gave 616, Got 895 | Re: Where to buy Circular Polarizing Filter and/or ND grads?? Quote:
Originally Posted by BrokenArrow Are Hoya polarizers the ones to go for? £25-40 seems quite high when there are others for around £10. Do you get what you pay for? | £25-£40 is quite resonable for a half decent filter, hoya are one of the cheaper options when it comes to filters and in particular polarisers, the high end manufacturers like B&W and Lee you can be looking at upwards of £70 for a polariser. I think given how useful polarisers are it's worth putting the boat out a bit and getting a decent one like hoya (I have two Hoya polarisers one 67mm, the other 77mm)
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
09-04-2008, 7:50 PM
#8 (permalink)
| | Veteran Member
Join Date: Jul 2005 Location: mickey marley's roundabout
Thanks: Gave 814, Got 705 | Re: Where to buy Circular Polarizing Filter and/or ND grads??
__________________ :: Flickr :: |
