29-02-2008, 8:57 AM
#1 (permalink)
Thanks: Gave 101, Got 59
Aquarium Photography
I have been trying to take some decent pictures of my aquariums and fish, had some that are ok. Johnny70's Aquarium Album some recent pics
I'm using a 400D with a 28-80 macro lens(sigma) getting a tripod and 430ex flash in the next two weeks
I'm finding getting the settings between the lighting and speed of the fish difficult as well as getting full tank shots with the flouresent lighting.
I'm pretty new at photography and would like to improve the shots I do.
Anyone help?
JOHNNY
29-02-2008, 9:19 AM
#2 (permalink)
Thanks: Gave 342, Got 509
Re: Aquarium Photography
For starters I wouldn't recommend you use a flash! It'll scare the fish and you will need to fire it directly at the tank which will give you a nasty glare from the flash bouncing off of the glass straight back at the camera.
Since fish rarely stop moving you need quite a fast shutter, so to get that you either need to up the ISO or use a nice wide aperture (or maybe even both). I'd be looking for something like 1/80th sec and faster for nice sharp results.
HTH.
Chris. Serial Procrastinator.
EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky
29-02-2008, 9:25 AM
#3 (permalink)
Thanks: Gave 128, Got 466
Tripod and remote release will definately help improve things.
My flickr Pentax K20D/ K10D Sigma 10-20mm/Tamron 70-300mm/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
29-02-2008, 9:38 AM
#4 (permalink)
Thanks: Gave 309, Got 316
29-02-2008, 10:51 AM
#5 (permalink)
Thanks: Gave 151, Got 123
Agree with everything Tomato1 says above
One from my aquarium
Clicky Piccy
Kit: Canon 50D,Canon 400D,Canon Grips,Canon EF-S 10-22mm f/3.5-4.5,Canon EF 50mm f/1.8,Canon EF 100mm f/2.8, Canon EF 70-200mm f/4 L IS,Canon EF 100-400mm f/4.5L IS USM,Canon Extender EF 2x II,Canon 580EX,Canon HD HF10, Manfrotto O55PROB tripod and 3-way head 804RC2.
MY PHOTOS ON FLICKR
29-02-2008, 12:46 PM
#6 (permalink)
Thanks: Gave 2, Got 5
You may want to try wrapping a black clock around the front of your lens when it is near the glass as it should cut down on reflections and light coming in from the wrong angle.
It works when shooting through glass at the zoo, so it may be worth it on your aquarium.
29-02-2008, 3:40 PM
#7 (permalink)
Thanks: Gave 56, Got 33
Well you could do something like this. I find it easier to use an image to explain, sorry for my poor Ms Paint skills.
So, you just put your external flash or a lamp on the side of the tank and use a piece of paper as a diffuser, or if you have a diffuser that's better. This way you get more flattering results for your tank and you have enough light to use faster shutter speeds, and you don't have the flash reflections because there arent any!
Canon EOS 400D + BG-E3 Grip, EF-S 18-55mm, EF 50mm 1.8, EF 35-105mm, Sigma 10-20mm EX, Sigma 120-300mm F/2.8 EX HSM, Lensbaby 2.0, Sigma 2X EX, Sigma EF-500DG Super Flashgun, Manfrotto 055XPROB +486RC2.
My Flickr
29-02-2008, 5:17 PM
#8 (permalink)
Cheers for the replies.
I was hoping for some idea's on what settings to use ie Tv etc and what ISO etc.
JOHNNY
29-02-2008, 6:01 PM
#9 (permalink)
Well, it mainly depends on the subject. If it's a fast moving little fish I would personally go for faster shutter speeds, if on the other hand was a bottom dwelling fish, ie a catfish I would choose a suitable aperture, since fish-movement would be minimal. As for camera settings, I would go for custom WB, choosing a white point on the available light, on the setting I suggested above and AV. You should choose the smallest aperture you can get, with shutter speeds you can get away with. It's easy to choose unrealisticly fast shutter speeds with TV, so just stick with AV and compensate with every shutter speed reading you'll get.
My Flickr
