18-01-2008, 9:33 AM
#1 (permalink)
Thanks: Gave 181, Got 30
Recommend me a wide angle lens
Hiya all,
I have a budget of around £300 and would like to know which wide angle lens would be ideal for my Canon 40d. Silly me I type in widescreen first!!!
All fixed set patterns are incapable of adaptability or pliability. The truth is outside of all fixed patterns...Be water my friend
18-01-2008, 9:40 AM
#2 (permalink)
Thanks: Gave 63, Got 153
Re: Recommend me a wide angle lens
I really love my Sigma 10-20mm and can be had from here (highly recommended throughout the forum) for £249.99!!
Canon 5D MKII + grip & 5D MKI + grip | Canon 20D | Canon 17-40 F4 L | Canon 24-105 F4 L IS | Canon 70-200 F4 L IS | Canon 50mm f1.4 | Canon 580EX | Manfrotto 055PROB Tripod & 486RC2 Head | Canon HF100 HD Camcorder
Blog
18-01-2008, 10:24 AM
#3 (permalink)
Good price - Cheers for that any more suggestions would be great. BTW are the aCanon lenses to expensive?
This is my 1000th post-yippee I think!!
18-01-2008, 10:45 AM
#4 (permalink)
Thanks: Gave 1, Got 4
I used a Canon EF 20-35mm f/3.5-4.5 zoom on my 10D which produced excellent results. Since then I have upgraded to the 5D and the 17-35 lens, but that is probably more than you want to spend.
I still have the 20-35mm lens, it is in good nick, no scratches, so if you are interested let me know.
18-01-2008, 11:11 AM
#5 (permalink)
Thanks: Gave 617, Got 895
I doubt you'd be dissapointed with the sigma 10-20, it's my favourite lens I own. Might be worth having a look at the Tokina 12-24 as well. If you could afford it I'd probably go with the canon 10-22 personally.
Panasonic TH50PX60,Nikon D300 & 12-24 DX, tamron 17-50 & 90mm 2.8, 70-300mm VR, Epson stylus pro 9800 printer.
18-01-2008, 11:37 AM
#6 (permalink)
Conspicuous Member
Thanks: Gave 1,143, Got 1,013
The Sigma is a popular lens here with a lot of users, but do consider both the Canon 10-22 and the Tokina (which betters the Sigma in thats it's a constant f/4)
I use the Sigma and have been happy with the image quality, it's nice and wide gives nice colour renditions, contrast and a good weight.
Some examples here, here, here and here
EOS 5D Classic~EF 24-70mm f/2.8L~EF 70-200mm f/2.8L IS~EF 50mm f/1.4~580EXII
Flickr Website Blog
18-01-2008, 11:54 AM
#7 (permalink)
Thanks: Gave 289, Got 425
I'm to go against the grain a little here - IMo the Sigma has pretty poor corner perfomance and you'll notice that on an UWA. I'd spring for either the Canon 10-22mm or the Tokina.
"All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon
18-01-2008, 12:05 PM
#8 (permalink)
Conspicuous Member
There is a test of numerous UWA's here and a specific test of the Canon 10-20 here.
User reviews of the Canon here, Sigma here and Tokina here
Flickr Website Blog
18-01-2008, 1:09 PM
#9 (permalink)
Thanks: Gave 35, Got 535
I recall Ken Rockwell rated the Canon above all the 3rd party lenses. I have the Tokina 12-24 btw. Very good, built like a tank. It's prone to flare though, and (like most Tokinas apparently), has quite a lot of CA.
18-01-2008, 1:24 PM
#10 (permalink)
Thanks: Gave 283, Got 558
for your budget i'd get the sigma 10-20. however if you look hard you might be lucky and pick up a 2nd hand canon 10-22 for just over 300
18-01-2008, 1:26 PM
#11 (permalink)
Thanks: Gave 211, Got 328
The Sigma 10-20 has terrible quality control issues. Think it's OK if you get a good one.
Two of my friends have the 10-20.
The first one god a good one on the third attempt (Nikon mount)
The second one decided not to stay with Sigma after getting a second duff one (Sony mount).
FYI - See this thread....
http://www.dynaxdigital.com/index.php?topic=4353.0
and this one (for the response from Sigma)
http://www.dynaxdigital.com/index.php?topic=4405.0
The Sigma 10-20 is not a lens to buy online, unless there is exceptional customer service.
If you are going to buy the Sigm, I would buy from a local dealer so that you can keep popping back and avoid the postage costs.
I have the Tamron 11-18, which was my second lens afer taking the second one back for being too soft. Think the Sigma gets better reviews though.
If it was my money - I would save and want to get the Canon.
18-01-2008, 3:00 PM
#12 (permalink)
Thanks: Gave 293, Got 898
Sigma 10-20 for me. Super lens.
18-01-2008, 3:29 PM
#13 (permalink)
Thanks: Gave 229, Got 281
Another vote for the Sigma 10-20.
One other alternative is the Canon 10-22, but it is a bit more expensive and wont fit on larger frame cameras if you want to upgrade from your 40D
18-01-2008, 3:36 PM
#14 (permalink)
True, but neither will the Sigma, or the Tokina, or the Tamron.
18-01-2008, 3:50 PM
#15 (permalink)
Conspicuous Member
They wll not work on the full frame cameras (though I think the Tokina will) but they wil be fine on the 1.3 crop range.
Flickr Website Blog
