20-12-2007, 6:12 PM
#1 (permalink)
| | Member
Thanks: Gave 62, Got 106 | Lens Recommendations
After much research and trying to work out how much cash I've got (im sure you've all seen the threads!) I finally managed to bag myself a Canon 350D + Kit Lens for £209 delivered (brand new).
I just couldnt justify spending roughly another £200 (£150 with cashback) on a 400D. Now I have heard the kit lens is pretty dissapointing so I'd like to get a cheap Canon lens to go with it, my choices so far as as follows:
Canon EF-S 18-55mm f/3.5-5.6 USM
CANON EF 38-76mm AF
Canon EF 35-80mm AF F4-5.6
Canon EF 28-80mm AF
These are considering my limited budget and I could get either one for roughly £35-45.
As im only a beginner I was hoping to get some views on which would be the best "all rounder" for me to start off with. I mostly shoot landscape, wildlife (although I know I'll be needing a much longer lense for this in future) and general photography such as buildings etc.
The Canon EF 28-80mm AF appeals to me the most due to the extra bit of zoom, but is there any downside to buying this over the others?
Thanks for all the help guys, sorry to be such a pain with all these "umming and arring" threads! |
20-12-2007, 6:36 PM
#2 (permalink)
| | Prominent Member
Thanks: Gave 1,025, Got 885 | Re: Lens Recommendations
Hi ya
I think the CANON EF 38-76mm AF is the kit lens so if I was you wouldn't get that. I could be wrong
I will have a look at the other lens for you.
But this is only my opinion, but for now play around with the kit lens,get use to the camera and save a bit more. There no hurry, you be better off geting something that's going to last you, maybe longer than the camera, than getting something you will not like and want to replace.
Two good lens that are value for money are
Canon EF 50mm f/1.8 II Lens which you can pick up for £56 but it is a fixed focal length of 50mm
Another is the Sigma 70-300mm f/4-5.6 APO DG Macro Lens £109.99.
Cheers Holo
Canon 40d, Canon 400d, Tamron 17-50mm f/2.8, Canon 50mm f/1.8,Sigma 70-200mm f/2.8, Canon 100mm f/2 Sigma 100-300 f4 Canon 430EX Speedlite
20-12-2007, 6:44 PM
#3 (permalink)
| | Member
Thanks: Gave 62, Got 106 | Re: Lens Recommendations
You may have a point there, the kit lens in question (with the 350D) is the EF-S 18 - 55 mm F3.5 - F5.6 II - may actually be the same as the first one I mentioned (although that is the USM version, and could be the on which comes with the 400D)
20-12-2007, 6:49 PM
#4 (permalink)
| | Prominent Member
Hi ya  meant Canon EF-S 18-55mm f/3.5-5.6 USM
20-12-2007, 7:02 PM
#5 (permalink)
| | Member
hehe, apparently the big complaint with is that its very soft at small apertures
20-12-2007, 7:45 PM
#6 (permalink)
| | Member
Thanks: Gave 758, Got 194 | Re: Lens Recommendations Quote:
Originally Posted by dfrear hehe, apparently the big complaint with is that its very soft at small apertures | Sure is,i knew after only 1 week that i would be buying another lens |
20-12-2007, 10:37 PM
#7 (permalink)
| | Member
Thanks: Gave 4, Got 8 | Re: Lens Recommendations Quote:
Originally Posted by dfrear After much research and trying to work out how much cash I've got (im sure you've all seen the threads!) I finally managed to bag myself a Canon 350D + Kit Lens for £209 delivered (brand new). | Where did you get that from? Do you know if there are any left?
Toshiba 37WLT66, SKY+, Sony PS3 60GB, Sony STR-DB940, looking for speakers. Canon EOS 40d, EF-S 18-55mm f/3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, 50mm 1.8 MKII. IPhone 3G 16GB
20-12-2007, 10:50 PM
#8 (permalink)
| | Member
Hi dave, I got it from eBay - there are about 16 left, brand new, full 12 month warranty. The item number is 360007345601.
Not to everyones taste, buying off eBay, but im happy with that sort of saving. It comes with a free 2GB CF card too.
I managed to get myself a Sigma 28-300mm F3.5-6.3 so that should see me through a while.
21-12-2007, 12:34 PM
#9 (permalink)
| | Member
Thanks: Gave 40, Got 87 | Re: Lens Recommendations
If you are 'only' a beginner stick with the kit lens to begin with, that's what it was meant for in the first place. Yeah sure it's not the best lens in the world but it isn't a complete dogs dinner and until you get more experience and know what kind of lens, in terms of focal lengths and speed, you really need you'll just be wasting your money. Also most of the lenses you mentioned are very old, and other than different focal length aren't really going to offer you anything better than the kit lens.
My advice is buy the camera with the kit lens. If you budget can be stretched to buying something with a focal range like a 24-70 or something that goes from around 50mm to 100-200mm on the second hand market (check out Sigma and Tamron lenses for better prices than Canon) than this will let you do more telephoto photography whilst you learn.
In a years time or whenever you feel that you are now outperforming the lenses (i.e. they are stopping you from getting the kind of shots you now know how to take), flog those lenses and invest in some better glass.
Basically learn to walk before you can run. Photography is an incredibly expensive hobby, or at least it can be. Don't fall into the trap of thinking that you have to have the best lenses/cameras in order to take good photos. You could have the best lens/camera in the world but if you don't know how to use them properly you still won't get the best from them. By buying competent gear you'll learn a lot and learn quickly without wasting your money.
HTH
__________________ My Kit: A camera and some lenses
21-12-2007, 1:27 PM
#10 (permalink)
| | Member
Hi Peak,
Thanks for the advice, that's roughly what I was thinking - which is mostly why I chose very cheap lenses which were quite old but would give me a bit more scope than the 18-55. I tend to be a sucker for a bit of zoom so getting the 28-300 for 60 quid was a pretty good start.
Time will tell just how good though! I am upgrading from an S6500fd so I guess thats why I was a little sceptical about "stepping down" to "just" 18-55mm.
21-12-2007, 2:49 PM
#11 (permalink)
| | Member
Thanks: Gave 106, Got 55 | Re: Lens Recommendations
Was the Sigma off ebay too? I only ask because I bought one and got the dreaded "Error 99" problem that some (usually Sigma) lenses get-meaning that to work they need to be rechipped. This is usually more likely to happen the older the lens is. I sold mine onto another Canon user,this time a film user where this error doesn't occur.
I hope you aren't as unlucky as me.
29-12-2007, 8:27 PM
#12 (permalink)
| | Member
Thanks: Gave 16, Got 6 | Re: Lens Recommendations
Dfrear
i have just had a look on ebay at the 350d. i am seriously considering buyingone, but would you have any concerns/ advice having just purchased one?
Also, is it the 350 Badged model, or the USA RebelXT model, and is it black or silver (not that that will change my mind)
Thanks in advance
JD
29-12-2007, 11:24 PM
#13 (permalink)
| | Member
hi johndow, when/if it arrives ill let you know
So yes, there are concerns - the seller isnt holding stock, but it is shipped from a UK seller. If you check feedback they have been having some trouble in the run up to xmas, I have been promised that it will be shipped on the 2nd of January when their supplier returns to work.
Basicly, if you don't mind the wait (although there may not be one now its after xmas) then go for it, but otherwise, buy elsewhere. I don't mind the wait if it saves me about 120 quid... Next cheapest new 350D was about £300
__________________ Kit: Canon 40D :: Sigma 17-70mm f/2.8-4.5 DC Macro :: Sigma 100-300mm f/4.0 EX DG IF HSM APO :: Slik Pro 400DX |
30-12-2007, 6:32 PM
#14 (permalink)
| | Member
I've bought one also and been told it will ship after 2nd January, will just have to wait and see but for the price it is a bargain.
01-01-2008, 7:56 PM
#15 (permalink)
| | Member
I'm a sucker for impulse buying, and usually regret it. I see the 18 available went pretty quickly, but if it is as good as it says, i will keep an eye out for any more.
It's the old "if it looks too good to be true, it usually is" eating away at me.
Fingers crossed it works out for you. i will be eagerly watching this space, and ebay (and prob kicking myself i didn't buy when i could have!)!!
JD
