20-12-2007, 5:27 PM
#1 (permalink)
Thanks: Gave 6, Got 5
recover my photo`s
Hi Guys
i deleated some photo`s by mistake from my sandisk , i have used recover my photos which has place them in a foulder but nothing will open them . can someone please help , they are nothing that can`t be taken again but i would like them back all the same
cheers
santana007
always have your camera.  try and stay cool in everyday troubles.. try and think of other`s we are all human , life is short
20-12-2007, 6:35 PM
#2 (permalink)
Thanks: Gave 62, Got 106
Re: recover my photo`s
You say nothing will open them, could you give us an example of what the filenames are like? It sounds like they may be missing the file extensions for some reason. Should hopefully be an easy fix if thats the case
20-12-2007, 7:37 PM
#3 (permalink)
HI
cheers for the responce , they are cr2 files , i have tried my sandisk recovery and recover my photo`s they both find the photo`s but as i say nothing will open them, they are named _MG_2998 and are around 11mb.
that is all i can tell you
cheers
santana007
20-12-2007, 7:40 PM
#4 (permalink)
Thanks: Gave 74, Got 64
.CR2 files are Canon RAW files. Try opening them with the Digital Photo Professional software that you should have with your camera.
20-12-2007, 7:50 PM
#5 (permalink)
hi brokenarrow . already tried m8 it just shows a blank box with this data
File name
_MG_2998.CR2
Camera Model Name
Shooting Date/Time
Tv(Shutter Speed)
Av(Aperture Value)
Metering Modes
Exposure Compensation
ISO Speed
Lens
Focal Length
Image size
0 x 0
Image Quality
Flash
White Balance
AF mode
Picture Style
Parameters
Tone Curve : -
Sharpness level : -
Pattern Sharpness : -
Contrast : -
Sharpness : -
Color saturation : -
Color tone : -
Color matrix
Color Space
santana007
20-12-2007, 8:07 PM
#6 (permalink)
Thanks: Gave 425, Got 2,079
How big are they? can you email one to me to have a go?
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
20-12-2007, 8:48 PM
#7 (permalink)
Hi m8
how are you .
around 11mb
rog
20-12-2007, 8:50 PM
#8 (permalink)
In still here, ill email my yahoo box which can ( i hope) take something bigger that 10 Mb otherwize try zipping it.
S3Stuff
20-12-2007, 9:02 PM
#9 (permalink)
cheers m8
it went took 6 mins
rog
20-12-2007, 9:19 PM
#10 (permalink)
Got it .. and it really is a bummer , wont open whatever trick Ive used
Sorry m8, Did try
S3Stuff
20-12-2007, 9:28 PM
#11 (permalink)
cheers m8
thanks for trying
rog
20-12-2007, 11:02 PM
#12 (permalink)
I'll have a go if you want to forward me the same? Should still be in your sent id imagine
20-12-2007, 11:08 PM
#13 (permalink)
cheers m8
just running a prog for deep scan .. so an over night job .. don`t think it will be anything different .. i`m on vista here but i have 2 p.c`s running xp maybe xp might cope better
at the moment i`m lost
what are the best compact cards togo for .. i have always used sandisc
cheers guys
busy time of the year ... and still you try to help
rog
21-12-2007, 9:05 AM
#14 (permalink)
I think your probably fine with sandisk, have you had any problems with the actual card? I assumed you'd accidentally lost the data?
21-12-2007, 9:58 AM
#15 (permalink)
hi m8 what it is i took some photo`s at our sons school of the kids with santa.
i gave all the photo`s to a friend to dish out as she has 3 sons that go to the school and know`s most of them . she took some to nursery and gave the others to the p.a . a woman stopped me and said her grandson`s photo was not there . i`m sure i only used one flash card so it has to be in the pile that are with the p.a .
but to make sure i wanted to check my other cards that i had wiped because i was going to london and wanted blank cards . if i only used 1 card and i`m sure i did then the photo has to be there . i have just managed to check 1 card and convert the photos from cr2 and open them with dng . and they are from chester zoo . i have managed 99 from 159 the 60 other files have a message saying there was an error parsing the file .
cheers for all the help
santana007
