03-12-2007, 8:59 PM
#1 (permalink)
| | Member
Join Date: May 2007 Location: Rainham, Kent. Garden of England
Thanks: Gave 136, Got 97 | Please be patient with me!
I’m just going to try the link that Flickr says you should use to link back to there site!
Fujifilm 1400Zoom 1.3mp my first digital camera : Fujifilm S602Zoom excellent super macro setting : Canon EOS 40D With battery grip : Canon EFs 17-85 IS USM : Canon EF 75-300 USM : Canon EFs 55-250 IS : Canon Speedlite 580EX11 My Flickr |
03-12-2007, 9:00 PM
#2 (permalink)
| | Member
Thanks: Gave 136, Got 97 | Re: Please be patient with me!
Well that doesn’t work then!
03-12-2007, 9:02 PM
#3 (permalink)
| | Member
03-12-2007, 9:04 PM
#4 (permalink)
| | Member
03-12-2007, 9:06 PM
#5 (permalink)
| | Member
03-12-2007, 9:09 PM
#6 (permalink)
| | Moderator
Thanks: Gave 425, Got 2,078 | Re: Please be patient with me!
Dont use it
If you Have embedded an image here and you want to link it back to flickr
first
open the flick page to want to link to.. the copy its URL address ( httl ://..)
then open your post and select in full the line that relates to your image
[IMG] adcdxyz[IMG],
click on the icon that has the little world and link,
this will open a line where you can then past the url from flickr
click OK
This should then turn your image into a clickable link back to flickr
In fact this method can turn any thing into a link not just an image
HTH
__________________ S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine! |
03-12-2007, 9:12 PM
#7 (permalink)
| | Moderator
Ill try it for you :have a go now
03-12-2007, 9:12 PM
#8 (permalink)
| | Member
How can you tell what’s under the x, I thought that if you right click and select properties you could see what underneath it.
Bit baffling for an old boy like me, I bet you’re all having a laugh at my antics!
03-12-2007, 9:13 PM
#9 (permalink)
| | Moderator
No Ive actually done it for you and i learnt to do it on here..Honest
03-12-2007, 9:15 PM
#10 (permalink)
| | Prominent Member
Thanks: Gave 329, Got 1,159 | Re: Please be patient with me!
If you want to do this from scratch:
Copy the link to your flickr photo page
When you post a thread click the world with links icon in the tool bar and paste your link in here.
When it appears, the text within the link (a copy of the link itself) will be highlighted.
Go back to flickr, click in 'all sizes', select your size and then copy the url from the bottom window.
Back in your thread, click straight on the Mountain image and paste in your link.
You should be left with your link, and then within that the link to the image wrapped in [IMG] tags
Should work
03-12-2007, 9:17 PM
#11 (permalink)
| | Member
Thanks: Gave 136, Got 97 | Re: Please be patient with me! Quote:
first
[IMG] adcdxyz[IMG],
click OK
HTH | Right Senu Ill try that. http://farm2.static.flickr.com/1297/...624f3ebc13.jpg
03-12-2007, 9:23 PM
#12 (permalink)
| | Prominent Member
{URL="http://farm2.static.flickr.com/1297/1243787940_624f3ebc13.jpg"] {IMG} http://farm2.static.flickr.com/1297/...624f3ebc13.jpg{/IMG}[/URL}
note - in the above i've added the [IMG] tags in the correct places, but used {}'s to stop it working
Also, you need to link to the photo page, the one where the comments appear, rather than the link supplied in the 'all sizes' page
03-12-2007, 9:27 PM
#13 (permalink)
| | Member
Originally Posted by Liquid101 If you want to do this from scratch: Copy the link to your flickr photo pageWhen you post a thread click the world with links icon in the tool bar and paste your link in here.
Should work  | Where do I find the link to my flickr page?
03-12-2007, 9:29 PM
#14 (permalink)
| | Prominent Member
It's this one http://www.flickr.com/photos/10622924@N06/1243787940/
Copy it form the Address bar in the browser window.
Reason: Thanks Senu - sound much better
03-12-2007, 9:30 PM
#15 (permalink)
| | Moderator
Thanks: Gave 425, Got 2,078 | Re: Please be patient with me! Quote:
Originally Posted by lightpainter Where do I find the link to my flickr page? | On the address bar on the top of the page
I had linked to a larger image but for increasing the no of views, It is the page with comments that is the right one, The priciple is the same though
