Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 21st at 3:30pm and include delivery.
Old 12-09-2007, 7:49 PM   #1 (permalink)
py6km's Avatar
Thanks: Gave 230, Got 122
Exposure question - confused !
Just been reading Understanding Exposure, and there's something I don't get. In the section on low light/night photography, Bryan explains on most images that he meters from the dusky sky - fine. However, he meters at an aperture of, say, f/2.8 to get the corresponding correct shutter speed. He then recomposes the shot, but adjusts the aperture (to f/22 for example) and adjusts the shutter speed by a corresponding amount.
For example, if he meters off the sky at f/2.8, but then composes the shot proper at f/22, he adjusts the shutter speed given at f/2.8 by 7 stops/positions to give the correct shutter speed at f/22 (since f/22 is 7 stops from f/2.8).
My question is: why not just meter off the sky at the aperture you want to use int he shot, e.g f/22 ? Would that not give the same result ?
flickr
py6km is offline   Reply With Quote
Old 12-09-2007, 8:02 PM   #2 (permalink)
Thanks: Gave 293, Got 898
Re: Exposure question - confused !
Good question there. I'd hazard a guess that the camera meters more accurately the more light it has hitting the light meter therefore meter at 2.8 then close the aperture to what you want the shot to look like.
I think he says a few times about metering wide open then adjusting accordingly (too much maths for me though - not quite worked it all out yet).
Tobers is offline   Reply With Quote
Old 12-09-2007, 8:05 PM   #3 (permalink)
py6km's Avatar
Ok, yes, that makes sense. It would be interesting to see if the same results were achieved using his method and 'my' method
flickr
Old 12-09-2007, 8:09 PM   #4 (permalink)
Thanks: Gave 13, Got 8
I think that his camera did not have a shutter speed that corresponded to f2.8 @ 1/4 at f22 (30 seconds), so the exposure time could not be calculated if the metering was done at f22.
Metering first at f2.8 meant that he could calculate the correct shutter speed (for f22), and time it manually with his camera set to 'Bulb'.
Cadire is offline   Reply With Quote
Old 12-09-2007, 8:09 PM   #5 (permalink)
Liquid101's Avatar
Thanks: Gave 329, Got 1,159
This concept is a bit dated I think. There was a time when meters were more accurate when the lens was wide open - in fact some early lens/camera combinations required it.
Not sure that modern cameras and lenses would suffer this kind of thing. Might be worth experimenting though. That said, any subtle differences that these readings give would be meaning less when shooting in RAW.
flickr
Liquid101 is offline   Reply With Quote
Old 12-09-2007, 8:11 PM   #6 (permalink)
py6km's Avatar
So you think that metering at the aperture you want to use to take the shot would work, and his method is an artefact of his knackered out old camera/lenses?
flickr
Old 12-09-2007, 8:16 PM   #7 (permalink)
Thanks: Gave 342, Got 509
yeah dont worry about it. The lens is still wide open unless you press the depth of field preview button anyway.
Chris. Serial Procrastinator.
EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky
T0MAT01 is offline   Reply With Quote
Old 12-09-2007, 8:16 PM   #8 (permalink)
Well, I meter at the aperture I want so I think you're right - a historical throwback. Might be worth a few experiments though and it'll certainly get your brain around the aperture/shutter calculations.
Old 12-09-2007, 8:21 PM   #9 (permalink)
It depends if your camera has a shutter speed that long. If a 'correct' exposure was 30 seconds @ f22, and your camera had a maximum shutter speed of 15 seconds, how would you ever meter it? Using his method allows you to do that.
Old 12-09-2007, 8:21 PM   #10 (permalink)
py6km's Avatar
Cheers everyone - I'll give it a go.
While I'm on the subject of exposure, and for those familiar with the book - why does a shot taken using his 'Mr Green Jeans' approach need to be exposed at -2/3 below the reading you get when you meter off any greenery ?
I've not really figured out how to do that on my D200 yet - does anyone have any experience?
flickr
Old 12-09-2007, 8:28 PM   #11 (permalink)
Liquid101's Avatar
While I'm on the subject of, for those familiar with the book - why does a shot taken using his 'Mr Green Jeans' approach need to be exposed at -2/3 below the reading you get when you meter off any greenery ?
The exposure compensation button just below and the right of the shutter release. It's marked with a +/- hold this down and use the command wheel to set the compensation required. I always shoot at -0.7 - I feel the D50 exposes a little bright for my tatses. I think it roughly uses 3rd stop steps.
flickr
Old 12-09-2007, 8:32 PM   #12 (permalink)
py6km's Avatar
Would you adjust the exposure to -2/3 before or after you manually meter? I'm concerned that by changing the exposure manually, it will affect how the camera meters (i.e. it will try to compensate for the reduction I've made)
flickr
Old 12-09-2007, 8:33 PM   #13 (permalink)
Liquid101's Avatar
I'm pretty sure it wouldn't make any difference. If you set it before it will expose with the comp - set after and it will adjust the exposure.
flickr
Old 12-09-2007, 8:51 PM   #14 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 567, Got 1,191
I woudl think that modern dslr actually work out exposure with the aperture wide open then they work out the maths themselves based on your set fstop. IE When you push the button for exposure lock the aperture doesn't close down through the viewfinder......it only closes the aperture when you actually do the exposure.
Gordon
My Photos: Flickr
Blog with some of my pics on it
Gordon @ Convergent AV is offline   Reply With Quote
Old 12-09-2007, 8:51 PM   #15 (permalink)
py6km's Avatar
@ Liquid101
Maybe I'm getting mixed up here, but wouldn't that therefore mean that there was no point in adjusting the exposure ?
I mean, if you set it before, and then meter, the camera meters taking into account the exposure compensation; set it after, and the camera adjusts the shutter speed (or whatever) to maintain the exposure at the metered level - in other words, the camera works to negate the effect of the exposure compensation you've specified in order to get what it thinks is still correct ?
Would you not need to meter, and record those values, then set the exposure compensation to -2/3 and use the values for exposure obtained prior to your compensation in such a way that the camera is not able to adjust anything to try to get back to 0eV...?
flickr
confused, exposure, question
