Originally Posted by Darkstar_surfer Having a card reader as a back-up is always a great idea, but since I went through this problem myself last week I know how annoying it can be when your new camera has an apparent problem.
My problem was due to not having the correct driver. This can be found on Cannon's support page. Have you tried the canon twain driver 6.6.3. |
You no doubt refer to
THIS THREAD
I would suggest that having a card reader is far better than just a backup.
While I totally agree that it is immensely irritating to feel your new camera and PC are not getting on Im not as sure there is a reason why you should feel that using the bundled software for download is the "ideal way".
Certainly there is no harm in seeking the "right" driver as suggested above
A few advantages of card readers
They are affordable, portable and require no drivers on most PCs running Win 98se and above (ie 2000-vista), and Macs
If you have several PCs , It may not be possible (or desirable) to install Canon software on all of them
Using a card reader routinely means you can have a card in the camera shooting and still be able to download ( great if out and about ,have more than one card and you have a laptop/PC to download to)
Card readers are considerably faster for download
You don't drain your cameras battery just for download :also, if it isn't well charged the download may get corrupted
Many programs ( Adobe Photoshop Elements comes to mind) automatically detect both the card with images in a card reader, as well as a connected Camera for downloading and "cataloguing" images
As such some cameras even come with a card reader in the box
I am a great fan of the RAW software DPP that comes with Canon DSLRs but while Zoombrowser is pretty useful, I dont consider it Essential
