20-04-2007, 1:24 PM
#1 (permalink)
| | Prominent Member
Thanks: Gave 367, Got 539 | Walkabout Zoom equal to the quality of the 50mm f1.8
Hi all
I'm so taken with my little Canon 50mm f1.8 that I'm always really reluctant to get out my canon kit lens, which is spoiling some opportunities as 50mm isn't quite as wide as I thought it would be (I guess 35mm is the natural lens for a cropped sensor).
So...
I'm looking for a walkabout zoom lens for my 400D which will offer equal or greater image quality to the 50mm so that I can leave it on the camera.
I was initially looking at the Tamron 17-50 f2.8 and the Sigma 17-70 f2.8-4.5 Macro but I'm worried that I wont like the colours enough (this is something the reviews rarely go into so I'm a bit unsure as to what the variances are between lenses). Important things are:
Colour, sharpness, bokeh, CA, wide aperture. Things I don't mind compromising on:
Build, size/weight, geometric distortions (I think - maybe I don't realise how much this can effect the quality of images), wideangle (i.e. maybe I'd be happy with 24mm as the widest - maybe  ) Pricewise - I just want something as good as the 50mm. If it costs more to get this, I'll wait a while and save up.
Your thoughts would be appreciated.
tt
20-04-2007, 1:48 PM
#2 (permalink)
| | Moderator
Thanks: Gave 425, Got 2,080 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8
While the build quality of the 50mm 1.8 is so so, its image quality is hard to match by any wide angle zooms at the £2-350 mark . It is exceptional VFM.
What you should aspire for is something better much than the kit lens,( not really comparing to the 50)
The Sigmas and Tamron you list fit the bill perfectly. They are both quite well built and barrel distortion below 24mm can be fixed in software
Even the 50mm 1.4 ( which is 3-4 x the cost of the 1.8) isnt 3-4x its quality
The quite costly 17-55 2.8 USM IS is probably good enough to stop you from wanting the fifty as much but it is almost 8x its cost
The 17-85 ( if you can get it for £250) with Canons rebate will give you a fair range but not in the class of the fifty and If you dont need IS , ect the Tamron and Sigma are more of a bargain and are said to get sharper images
I like it but still use the 50mm 1.4 whenever appropriate .. its no match
20-04-2007, 1:48 PM
#3 (permalink)
| | Ex Member
Thanks: Gave 2, Got 169 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8
I know you said you wanted something to leave on the camera, but...
Why does it have to be a zoom? If you like the image quality and the speed then why not go with a Sigma 20 1.8 (£200) and a Canon 35 f2 (£162) or Sigma 30 1.4 £229.
You've suddenly got approx the coverage of a 17-50 2.8 zoom all at f1.8 or faster and with image quality that'll blow away the Tamron (compare 2.8 on the Tamron to 2.8 on any of those primes.)
That's my lineup anyway (but in Minolta flavour), and I absolutely love it. I regularly pull out my camera and people ask me why I'm shooting pictures without flash, isn't it too dark?
If you do want high speed zooms then the fastest it gets (bar Olympus! Who have an amazing looking f2 zoom) is f2.8 with Sigma's 18-50, Tamron's 17-50 (supposed to be excellent, my friend swears by his), Tokina's 16-50 or whatever Canon offers.
20-04-2007, 1:56 PM
#4 (permalink)
| | Moderator
Fast Primes will always the lenses to own but a walkabout lens for candids and the need to not carry around a bag of lenses does have its place.
20-04-2007, 2:04 PM
#5 (permalink)
| | Prominent Member
Thanks: Gave 367, Got 539 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8
Thanks guys
I'll certainly keep the prime route in mind, but if I can get close in a zoom it will get used far more.
ok - so lets for a second assume that money is no object - is it still difficult to match the 50mm f1.8?
Senu, you mention the Canon 17-55 2.8 USM IS and it is on my list. For some reason I was assuming that the addition of IS was going to mean that the IQ wasn't much better than the Tamron/Sigma. What are your thoughts on this?
If £5-600 will do it for me, at least I know what to aim for and I can decide whether to wait or not.
Thanks again
tt
20-04-2007, 2:06 PM
#6 (permalink)
| | Prominent Member
Thanks: Gave 283, Got 558 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8
I'm very happy with my sigma 17-70
Colours are nice, pictures are sharp and it's good value for money and won't break the bank!
20-04-2007, 2:12 PM
#7 (permalink)
| | Moderator
The 17-55 is an L grade fast lens with IS . It is justifiably costlier but I think that you need to look at these Lenses in the proper context.
Sometimes the cost difference doesn't translate to an equivalent difference in quality
I have in a recent post come to the defence of the much maligned 17-85 compared to the 17-55 but the latter costs £2-250 more: Is it worth that more?
Probably.. certainly more on the 30D than maybe the 350D but if money is tight, the Tamron , Sigma will do well... any shortcomings can be overcome by shooting carefully, Using RAW when appropriate and using PS
The big differences are not noticeable in the print sizes that most of our prints end up in
However there is no doubt that Good lenses always seem to hold their value and outlast bodies but VFM is equally Important as even the kit lens is usable until it gets replaced
20-04-2007, 2:18 PM
#8 (permalink)
| | Prominent Member
Thanks: Gave 293, Got 898 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8
Another vote for the 17-55. Very sharp - I dont use the 50mm very often now I have this lens. It's really really good - you'll be impressed.
20-04-2007, 2:40 PM
#9 (permalink)
| | Prominent Member
Thanks Tobers
At the moment I'm leaning towards spending more to get a lens I'm satisfied with.
I hear what you're saying re VFM Senu, but I'm seeing it like this - spend £250 and think twice about whether the fifty will be better, or spend £500 and just get on with shooting + it seems there is no better zoom lens on the market.
Of course if I spend £500 on the 17-55, then I've got no money for a longer lens so it all needs some careful consideration.
What I am surprised about is that even with an imaginary unlimited budget, it seems there is no perfect lens.
Thanks for the help guys
20-04-2007, 2:54 PM
#10 (permalink)
| | Prominent Member
Thanks: Gave 293, Got 898 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8 Quote:
Originally Posted by tryingtimes What I am surprised about is that even with an imaginary unlimited budget, it seems there is no perfect lens. | You've got that right. Dont let it stop you looking & trying to find it though - that's part of the fun.
By the way, the 17-55 will not fit on a 5D or 1D as its EF-S fit not plain EF. If you do go to a 5D, then you'll be looking at a 17-40L or 24-100L probably. More money!! However, you'll probably like the 17-55 so much that you wont bother with a 5D and will go with a 30D (or its successor).
In the meantime, its wierd having a lens worth twice as much as your camera body!
20-04-2007, 3:06 PM
#11 (permalink)
| | Prominent Member
Thanks: Gave 289, Got 425 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8 Quote:
Originally Posted by senu Fast Primes will always the lenses to own but a walkabout lens for candids and the need to not carry around a bag of lenses does have its place. | I'd go one further and say that for most people, most of the time, a constant aperture standard zoom will get more use, more often.
I've got 2 very nice primes but 80% of my weddings are shot with a 24-70 or 70-200 f2.8. It suits the way I shoot more than primes most of the time. The primes have their place.
__________________ "All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon |
20-04-2007, 3:06 PM
#12 (permalink)
| | Moderator
Regarding the "transferability" of lenses
The XOD series ( 10,20,30D) are a step up from the 350-400 ( X00D seires) and there may be a 40D to tempt you when the 400D starts feeling like it need to go..
The 5D camera costs more than a few 400Ds put together  !!
Anyhow good glass can be sold on with little loss so I wouldn't be put off otherwise there is the 17-40mm L which is not an EF-S but it is an f4... |
20-04-2007, 3:07 PM
#13 (permalink)
| | Prominent Member
Hi Tobers
Yes, the cropped sensor thing comes up all the time when you're wanting a widish zoom. Who knows what is in my future. I must say it's hard to see myself growing out of the 400D, there seems to be every type of photo style looking excellent on Flickr using it.
After you posted I went off looking at the 17-40L again - it's the f4 which puts me off a bit, otherwise at £400 it's not too bad value.
Then I read Ken Rockwell saying that the kit lens is nearly as good as the 17-55! arghh! |
20-04-2007, 3:10 PM
#14 (permalink)
| | Moderator
Thanks: Gave 425, Got 2,080 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8 Quote:
Originally Posted by tryingtimes Hi Tobers
...After you posted I went off looking at the 17-40L again - it's the f4 which puts me off a bit, otherwise at £400 it's not too bad value. | It is good but ...: do you really see a 5D coming your way soon ?? Quote:
Then I read Ken Rockwell saying that the kit lens is nearly as good as the 17-55! arghh! | I'm sure it was a typo......  |
20-04-2007, 3:19 PM
#15 (permalink)
| | Prominent Member
Thanks: Gave 367, Got 539 | Re: Walkabout Zoom equal to the quality of the 50mm f1.8 Quote:
Originally Posted by senu It is good but ...: do you really see a 5D coming your way soon ?? | Not within a couple of years I don't think. I like travelling light too. I don't want to feel too encumbered with all the kit. Quote:
I'm sure it was a typo...... | I can't work out if you're laughing because this is the kind of thing that Ken comes out with all the time, or whether you really think it's a typo.
Either way he says it many times...
This if for the 17-55 IS Quote:
Bad News:
1.) Expensive.
2.) Same nominal zoom range and performance as the $100 18-55mm. Sorry, but looking at the images from my 8MP and 10MP bodies I don't see any more sharpness, and I got more consistent autofocus accuracy with the 18-55mm.
3.) Doesn't focus as close as the $100 18-55mm.
3.) Big lens; feels heavy on Digital Rebels.
| There's lots more on the review page of both lenses.
Anyway - he makes some good points about cost of lenses versus the cost of a holiday to take some better photos.
