20-04-2007, 8:38 AM
#1 (permalink)
| | Senior Member
Thanks: Gave 72, Got 111 | Damn eBay!
I just happened to search for Sigma lenses with a Pentax fit on eBay this morning and was presented with the 14mm f2.8 for £350........I bought it!
20-04-2007, 9:09 AM
#2 (permalink)
| | Member
Thanks: Gave 151, Got 123 | Re: Damn eBay!
Ah the lens bug
__________________ Kit: Canon 50D,Canon 400D,Canon Grips,Canon EF-S 10-22mm f/3.5-4.5,Canon EF 50mm f/1.8,Canon EF 100mm f/2.8, Canon EF 70-200mm f/4 L IS,Canon EF 100-400mm f/4.5L IS USM,Canon Extender EF 2x II,Canon 580EX,Canon HD HF10, Manfrotto O55PROB tripod and 3-way head 804RC2. MY PHOTOS ON FLICKR |
20-04-2007, 9:26 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 72, Got 111 | Re: Damn eBay! Quote:
Originally Posted by jenufa Ah the lens bug  | The Tamron version is £800ish and from the reviews I've found online the Sigma is supposed to be better so £350 isn't too bad methinks! |
20-04-2007, 9:47 AM
#4 (permalink)
| | Senior Member
Thanks: Gave 37, Got 175 | Re: Damn eBay!
Nice  Enjoy. The only drawback with this one was the fact that the hood was in-built so no chance for filters. Be careful with it and make sure you post some snaps when it's here
__________________ w: www.randomphotos.net #: Canon 1D Mk III - Bunch of Lenses. Bag full of other stuff :# |
20-04-2007, 9:49 AM
#5 (permalink)
| | Member
Gets some good reviews  . Post some shots of what it can do when you get the time.
20-04-2007, 9:59 AM
#6 (permalink)
| | Prominent Member
Thanks: Gave 373, Got 734 | Re: Damn eBay! If you're after Sigma or other 3rd party lenses, check this out. |
20-04-2007, 11:15 AM
#7 (permalink)
| | Senior Member
Originally Posted by h4rri Nice  Enjoy. The only drawback with this one was the fact that the hood was in-built so no chance for filters. Be careful with it and make sure you post some snaps when it's here  | It can take gel filters....
20-04-2007, 11:19 AM
#8 (permalink)
| | Senior Member
Originally Posted by Pirate!! | Without a bottomless pit of money it's so hard to make a choice isn't it! I could have saved £80 and bought the 10-20 but I would lose out on the speed...
I will try the 14mm and if I don't get on with it I can always put it back on eBay!
That 10-20 Sigma is great as it's a DC lens, designed for APS-C sensors, so you get an actual 10mm!!!!
20-04-2007, 11:22 AM
#9 (permalink)
| | Senior Member
Thanks: Gave 37, Got 175 | Re: Damn eBay! Quote:
Originally Posted by baldrick It can take gel filters.... |
Ah I was reading DP and it mentioned this as the only drawback
It is a damn fine lense
#10 (permalink)
| | Senior Member
Originally Posted by baldrick It can take gel filters.... | Can you get ND Grad gels?
20-04-2007, 12:12 PM
#11 (permalink)
| | Prominent Member
Thanks: Gave 367, Got 539 | Re: Damn eBay!
Cokin do a big mount to fit on the outside of lenses for their systems.
It has 3 grubscrews (I guess they may mark the lens).
Sizes are max 84mm for P-series and max 118mm for X-PRO.
Just a thought
#12 (permalink)
| | Ex Member
Thanks: Gave 2, Got 169 | Re: Damn eBay! Quote:
Originally Posted by baldrick That 10-20 Sigma is great as it's a DC lens, designed for APS-C sensors, so you get an actual 10mm!!!! | This is not true! It being a DC lens means it's designed for the smaller sensor of an APS-C camera. It won't cover the full 35mm frame, you'll get serious vignetting. It doesn't mean you get a true 10mm, it's still converted, so it'll work out as 15mm or 16mm, depending on the camera you mount it on.
That 14mm prime looks great, can't wait to see some shots |
20-04-2007, 12:33 PM
#13 (permalink)
| | Senior Member
Originally Posted by tryingtimes Cokin do a big mount to fit on the outside of lenses for their systems.
Just a thought | Isn't the problem with filters on a fast ultra wide angle lens just the sheer size/shape of the front element? Surely you'd need a bowl shaped filter or an huge piece of flat glass to cover the whole lens?
20-04-2007, 12:35 PM
#14 (permalink)
| | Ex Member
The problem for this particular fast ultrawide is that it's hood doesn't come off and that it's got no filter threads!
20-04-2007, 12:38 PM
#15 (permalink)
| | Prominent Member
Thanks: Gave 367, Got 539 | Re: Damn eBay! Quote:
Originally Posted by baldrick Isn't the problem with filters on a fast ultra wide angle lens just the sheer size/shape of the front element? Surely you'd need a bowl shaped filter or an huge piece of flat glass to cover the whole lens? | Yes - it would need some investigation. The Cokin X-Pro filters are 130mm wide though so might well do the trick.
However they are very expensive - I think an X-Pro polarizer is £200
