Re: Blue Tinge on pictures
Certainly looks like the white balance is set to Tungsten which will result on cooler and bluer images if shot under sun light which tends to be around 5600k in the UK for most of the year.
As Liquid101 says you could set your camera to auto white balance however I would suggest that you set it to cloudy. The reason for this is that setting it to cloudy will give warmer colours than auto BUT you need to remember to change your white balance setting when shooting indoors or under artificial light.
Alternatively shoot in RAW and then you can change the temperature after you've take the shot.
My Kit: A camera and some lenses
