Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 21st at 10:30pm and include delivery.
Old 31-01-2007, 10:59 PM   #1 (permalink)
Thanks: Gave 1,025, Got 885
Tripod advice
Hi ya
Was going to get one in the end so might as well ask. Looking for a tripod, nothing too expensive and light weight got to be as cheap as chips
Have a 400d with kit lenses at the moment.
Was looking at this
Have seen this in real life and it is very light.
Cheers for any advice.
Holo
Canon 40d, Canon 400d, Tamron 17-50mm f/2.8, Canon 50mm f/1.8,Sigma 70-200mm f/2.8, Canon 100mm f/2 Sigma 100-300 f4 Canon 430EX Speedlite
Holowlegs is offline   Reply With Quote
Old 01-02-2007, 12:40 AM   #2 (permalink)
BananaTiger's Avatar
Thanks: Gave 46, Got 116
Re: Tripod advice
I don't have the one that you have, but I have the Manfrotto 725B tripod which has a ball head. Love the tripod. It's really light and can hold my canon 350d with sigma 17-70/canon 85 with no problems. If it's anything like that, should be able to cope with your 400d with kit lens with ease.
Canon 40d | Canon 24-105mm F4 L | Sigma 17-70mm | Canon 85mm f1.8 | Canon 50mm f1.4 | 430EX - (Flickr)
Xbox 360 | Hitachi 28LD5200 | Humax 9200T | Onkyo 515 + Mordaunt Short 902i
BananaTiger is offline   Reply With Quote
Holowlegs (01-02-2007)
Old 01-02-2007, 6:26 AM   #3 (permalink)
PaulBoy's Avatar
Thanks: Gave 51, Got 87
Re: Tripod advice
Hi - Manfrotto make great tripods - for a camera & kit lens the one you linked is decent enough although the fact that it has FOUR section legs would annoy the hell out of me - can you not go somewhere to try some tripods out? Then check out 3Bay (got my first £60 tripod there for a tenner!)
I was once told to buy a good tripod once and that does not mean cheap as chips unfortunately - there is always a compromise between size weight & price (esp if you go for carbon fibre to keep the weight down)
Most people who want to use a tripod with their bigger zoom lenses will go for a set of tripod legs & a separate "head" (usually a ballhead for size & usability) & spend between £100-£200 (I've seen the heads only for £500 )
Just my opinion of course - all depends on what you want out of the thing really ... Paul
"I can't complain but sometimes I still do - Life's been good to me so far"
Gadget List: AV - Denon Kef REL Pioneer Sky+
DSLR - Between cameras at the mo
For Sale:
PaulBoy is offline   Reply With Quote
Old 01-02-2007, 9:07 AM   #4 (permalink)
Astaroth's Avatar
Thanks: Gave 18, Got 70
Re: Tripod advice
I would second the fact that a tripod is effectively for life (there isnt really much on them that can malfunction) and so you probably should get the best you can afford and then you are set.
If you want to just play with a tripod then the 7 day shop often have budget ones available for £10 or less which would be fine for just the kit lens and in the future if you were to buy a better one then the cheapo could be used for mounting a flash or such
In darkness a blind man is the best guide. In an age of insanity is a madman the best leader?
I'm Playing....
Astaroth is online now   Reply With Quote
Old 01-02-2007, 11:30 AM   #5 (permalink)
toadoftoadhall's Avatar
Thanks: Gave 2, Got 25
Re: Tripod advice
looks like a good tripod, tempted myself.
I have others, nice sturdy ( read heavy) tripods that I keep in the boot of the car, just in case, but being light, it lends itself to being carried around and actually being used.
Light tripods are great if you are travelling abroad too, especially with baggage weight restrictions.
Try carrying around a 3 kilo tripod all day, and you'll soon wish you had bought this one.
toad
toadoftoadhall is offline   Reply With Quote
Old 06-02-2007, 8:45 PM   #6 (permalink)
Re: Tripod advice
Hi all
Got the tripod today. Had a look at about 6 or 7 off them. Ended up going with the Manfrotto 718B. It was the one I felt most comfortable with. Some were too lite for my liking and others just to big and heavy.
Tried it out tonight and really happy with it.
Cheers Holo
advice, tripod
