| Re: 8GB high speed CF - £42 :O
There were some 4GB CF cards for £10 on the 7dayshop the other day.
Personally I wouldnt want the risk of that much data on a single card that could fail and so on my 350d with its file size I think 1gb is more than enough... if you had a higher resolution camera then something a little bigger may be better.
__________________ In darkness a blind man is the best guide. In an age of insanity is a madman the best leader? I'm Playing.... |
