Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 25th at 6:30am and include delivery.
Old 29-01-2007, 9:49 PM   #1 (permalink)
denno75uk's Avatar
Thanks: Gave 248, Got 531
Long lens for 30D
I have searched the forums and found some advice on this subject but, anyway....
That dreaded lens bug is nibbling away since I got my 30D. Got the kit lens and had a 28-105 USM II already and they are in my bag full time. The kit lens will do fine for now as far as wide end goes but need something a bit longer than 105mm. I have a 75-300 USM III to trade/sell as it just doesn't have a wide enough aperture to be useful hand held which is how I want to use it. Also, despite stopping down a bit and using a tripod, I just can't seem to get it as sharp as I'd like.
Ideally I would like something 'all-round' but accept the limits of those types of lenses so I'll keep the kit lens and 28-105 but need recommendations for replacing the 300.
Bearing in mind my issues with the Canon 75-300 4-5.6 USM III I have, what are my options for improving on this for around £300? Is this figure unreasonable to get something to fit my criteria? On a APS-C, is 200mm enough for wildlife photography?
denno75uk is offline   Reply With Quote
Old 29-01-2007, 10:03 PM   #2 (permalink)
Astaroth's Avatar
Thanks: Gave 18, Got 70
Re: Long lens for 30D
Given you have a 300mm zoom you should be able to go out an limit yourself to only going up to 200mm and see if it is enough for you.
Personally I find that 300mm is too short even on a 1.6x crop factor camera for my tastes which is why I would want to ideally go up to 400mm or more (and possibly a 1.4x teleconvertor)
In darkness a blind man is the best guide. In an age of insanity is a madman the best leader?
I'm Playing....
Astaroth is offline   Reply With Quote
Old 29-01-2007, 10:12 PM   #3 (permalink)
Matty777's Avatar
Thanks: Gave 18, Got 22
IMO be best to save you £'s up and get a Canon 100-400mm. They go for about £800 secondhand.
Or maybe a 70-200mm 2.8 and a tele-converter. IS is big money £1000+ so look for a secondhand Non IS (£500-600)
Lots of good deals can be had on POTN http://photography-on-the.net/forum/index.php Good Canon resource site.
(Mods sorry if the link has broken any rule, scrach it if I have )
PSN: VegasIII
HDTV: Samsung LE32R73BD DSP: Onkyo TX-SR506 DVR: Panasonic DMRES20 Sat: Sky HD Speakers: Mission/KEF
VCR: JVC S-Vhs Rack: Duo-Oppli Console: PS3 (40Gb) / PS2 /
Matty777 is offline   Reply With Quote
Old 29-01-2007, 11:36 PM   #4 (permalink)
Thanks: Gave 0, Got 58
Depends what you mean by wildlife... i've gotten stuff with the 70-200 but find the 400mm is typically required.
tyefi is offline   Reply With Quote
Old 30-01-2007, 4:46 PM   #5 (permalink)
Johndm's Avatar
Thanks: Gave 21, Got 39
Canon 100-400L Series.
You won't ever want to take it off the camera...
Expensive yes, but worth every penny. If you want quality, then it will cost.
You have a semi pro body, you need to put quality pro glass on it to use your camera to its full potential.
Same principle as AV, if you put rubbish in, you'll get rubbish out..
Johndm is offline   Reply With Quote
30d, lens, long
