Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 24th at 9:30pm and include delivery.
Old 05-12-2006, 10:42 AM   #1 (permalink)
Thanks: Gave 6, Got 5
studio photrography
hi guys
i`m after buying some studio gear. i have a canon 350d and canon 400d
i have been told the flash units can damage canon because of th voltage used , so i want a kit that uses a transmitter.
i want to spend around £500 on a studio kit . can someone please advise which to go for . and please post a link to a site to buy it from
cheers
santana007
always have your camera. try and stay cool in everyday troubles.. try and think of other`s we are all human , life is short
santana007 is offline   Reply With Quote
Old 05-12-2006, 10:55 AM   #2 (permalink)
h4rri's Avatar
Thanks: Gave 37, Got 175
Re: studio photrography
Who told you that and to which flash units were they referring? I have heard this said about older pre or early TTL units. The 430 & 580EX units are safe enough to use though as they are designed for these bodies
As for studio lighting, have a root through the forums as this has been said before with some great reviews listed in the topic IIRC
w: www.randomphotos.net
#: Canon 1D Mk III - Bunch of Lenses. Bag full of other stuff :#
h4rri is offline   Reply With Quote
Old 05-12-2006, 11:49 AM   #3 (permalink)
sorry h4rri , i should have been clear , i have the 580ex, what i mean is the studio flash units . because the connect to the hot shoe the voltage can damage some canon digital camera`s
cheers
santana007
Old 05-12-2006, 11:57 AM   #4 (permalink)
Thanks: Gave 13, Got 8
I use the Falcon Eyes radio trigger. Works fine.
I got it from here:
http://www.karlu.com/index.php?cPath=41_60_549
Edit: The exact model is the RF-125
Cadire is offline   Reply With Quote
Old 05-12-2006, 12:13 PM   #5 (permalink)
I got it from here:
cheers cadire,
what studio kit would you recomend to start out with i have around £500 could go to £600. i have looked at the d-lite kits, will they take radio triggers
santana007
Old 05-12-2006, 12:19 PM   #6 (permalink)
wabbitt's Avatar
Thanks: Gave 160, Got 116
As for a budget set of heads, I've read lots of very good reviews on the elinchrom D-Lite2 Twin head kit.
Read about it here.
At only £400 it's under budget too.
wabbitt is offline   Reply With Quote
Old 05-12-2006, 12:20 PM   #7 (permalink)
wabbitt's Avatar
santana007
Yep, they do. Any trigger that plugs into the sync socket will fire the heads.
I believe that there are IR triggers too that the slave cell will pick up.
Old 05-12-2006, 12:34 PM   #8 (permalink)
I had a rather smaller budget (especially after climbing onto the DSLR bandwagon), so I opted for the Interfit EX150 kit. They actually work very well (in my dining room!) so I have no complaints there.
I would have liked the D-Lites (or the new EX150 replacement), but there ya go
Old 05-12-2006, 12:39 PM   #9 (permalink)
h4rri's Avatar
Was browsing 7dayshop the other day and noticed they do very cheap reflector umbrellas, tripods and clamps etc. Might be a consideration as one setup was sub £50 and with a 430EX you would effectively have a cheap and portable light set-up
Old 05-12-2006, 1:31 PM   #10 (permalink)
cheers guys
very helpful coments, i think i might go for the d-lite although i am looking at this
---http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=005&sspagename=STRK%3AME WA%3AIT&viewitem=&item=150065343599&rd=1&rd=1
and this
--http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=015&sspagename=STRK%3AME WA%3AIT&viewitem=&item=250055584563&rd=1&rd=1
i`ll keep you posted
thanks for the quick responce
santana007
Old 05-12-2006, 10:32 PM   #11 (permalink)
barongreenback's Avatar
Thanks: Gave 124, Got 64
Not sure what your experience but you'd be well worth spending some of that budget on a half decent course and working out what you really want to work with. I personally like the Bowens kit but Elinchrom is good as well. I've been told by several people that the cheaper brands are a false economy.
Don't forget to budget for reflectors, additional softboxes, barn doors, bowls etc.
Just take it as read that I spend too much on gadgets and gizmos
barongreenback is offline   Reply With Quote
Old 05-12-2006, 11:34 PM   #12 (permalink)
cheers again for input ,
experience in portrait = none other than family = friends and what people say .. did some wedding pics for next door as a,, can i come along and take some .. they showed mine and not the pros at the night do. now they have said can i do the portraits of the kids.
money is not a problem .. i just don`t want to go to high if it will be a waste, as i don`t work and my wife goes out and earns while i look after our lad jake i would love to put something back
course + i hope do take one next year ..
been looking at this kit plus extras
http://www.karlu.com/product_info.ph...oducts_id=8450
cheers
santana007
Old 06-12-2006, 12:16 AM   #13 (permalink)
this was a pic taken of our little lad jake against a black back drop .
taken with a canon digital rebel . with canon 580ex flash
now i want to try and get to grips with it
cheers
santana007
Old 06-12-2006, 8:27 AM   #14 (permalink)
Just had another thought. Have you got a studio near you? Would probably be worth spending £50 hiring out their space and equipment to see what you like. Some people swear by softboxes, others like umbrellas, beauty dishes etc. It's a cheap way to find out what effects you like.
I think on that Interfit kit you'll find 150w to be quite underpowered, and you may need to site the lights very close to your subject, which can be intimidating and uncomfortable. I'd look at 250w minimum and if you're really making a long term investment then 500w would cover most of your needs. I've used my Canon with standard flash leads and never had a problem, barring a few misfires so you could probably hold off buying the radio trigger. That said if you're working with kids they're bound to trip over cables!
Old 06-12-2006, 10:08 PM   #15 (permalink)
cheers guys for all help .
i went for this kit with some extras .. went over budget , but the guy i spoke to was very helpful , and said once you get the kit please call and i`ll give you some tips .
once again cheers for your amazing responce
santanaoo7
photrography, studio
