Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 24th at 8:30am and include delivery.
Is anything we (the UK ) do , going to have any real impact ? johnscarlet Reducing Your Carbon Footprint 87 17-03-2007 8:26 PM
What has had the most impact on your life? Stuart Wright General Chat 65 26-08-2005 12:28 PM
Eltax Impact 8 Sub Tardis Subwoofers and Tactile Transducers 0 14-11-2003 4:33 PM
Big screen impact buns Projectors 0 11-06-2001 11:36 PM
Quality Vs Impact Jeff AV Amplifiers and Receivers 0 19-01-2001 3:33 PM
Old 09-11-2006, 2:06 PM   #1 (permalink)
monkeyleader's Avatar
Thanks: Gave 143, Got 66
Impact of IS
So I picked up the 24-105L the other day and played a bit with the impact of IS. I don't have the steadiest hands in the world so I'm sure you could open the shutter up a little bit more but from what I've done so far I've been VERY impressed - see here
MonkeyBlog
Monkey on Flickr
Black and Silver boxes most of which flash and beep !
monkeyleader is offline   Reply With Quote
Old 09-11-2006, 2:26 PM   #2 (permalink)
geofftelforduk's Avatar
Thanks: Gave 63, Got 153
Re: Impact of IS
Thats pretty impressive!!
Bit out of my budget at the mo!! Maybe when we meet in Brum you will convince me further!!!
Canon 5D MKII + grip & 5D MKI + grip | Canon 20D | Canon 17-40 F4L | Canon 24-105 F4L IS | Canon 70-200 F4L IS | Canon 50mm f1.4 | Canon 580EX | Manfrotto 055PROB Tripod & 486RC2 Head | Canon HF100 HD Camcorder
Blog
geofftelforduk is offline   Reply With Quote
Old 09-11-2006, 2:56 PM   #3 (permalink)
Thanks: Gave 23, Got 40
Re: Impact of IS
Looks more like the focus is out on the non-IS image... quite a significant difference, though!
My Flickr stream
Chunder is offline   Reply With Quote
Old 09-11-2006, 3:00 PM   #4 (permalink)
Re: Impact of IS
You know I thought that too but it was in focus through the viewfinder ...
MonkeyBlog
Monkey on Flickr
Old 09-11-2006, 4:41 PM   #5 (permalink)
Radiohead's Avatar
Thanks: Gave 289, Got 425
Re: Impact of IS
It works doesn't it - just remember that it doesn't help stop movement of subjects, something to bear in mind with IS in low-light shooting people. (I know you know this already)
"All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon
Radiohead is offline   Reply With Quote
Old 09-11-2006, 6:10 PM   #6 (permalink)
onefivenine's Avatar
Thanks: Gave 687, Got 666
Re: Impact of IS
Those shots are like night and day. It certainly does the job.
Does that lens have two IS modes - one for horiontal panning?
onefivenine is offline   Reply With Quote
Old 09-11-2006, 6:25 PM   #7 (permalink)
Thanks: Gave 231, Got 211
Re: Impact of IS
No, only on the longer lenses.
AV: Panasonic TH-42PV500 (TX-P58V10 coming soon), Panasonic TX-P37C10, Humax HDR, Panasonic DMP-BD35, Onkyo TX-SR876, Monitor Audio Radius 225HD's front, 180HD's rear and RSW-12 sub. Xbox 360, Wii
Jazz Monkey Jr is offline   Reply With Quote
Old 09-11-2006, 6:28 PM   #8 (permalink)
Kaoshan's Avatar
Thanks: Gave 8, Got 20
Re: Impact of IS
The 24-105 does not have a mode switch for IS. It is either on or off! I tend to have IS off on my 24-105 most of the time but use it all the time on the big zooms where it is extremely worth while.
Canon EF 28-135mm f3.5-5.6 IS USM lens for sale.
Kaoshan is offline   Reply With Quote
Old 09-11-2006, 6:44 PM   #9 (permalink)
Thanks: Gave 342, Got 509
Re: Impact of IS
Any particular reason for that? Do you use it on a tripod instead?
Chris. Serial Procrastinator.
EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky
T0MAT01 is online now   Reply With Quote
Old 09-11-2006, 6:51 PM   #10 (permalink)
Kaoshan's Avatar
Re: Impact of IS
Nope, I use it handheld. To be fair, in situations where I might need IS, which would normally be indoors and I don't need the extended range, I'll switch to using the 24-70 f2.8 lens.
One thing I have discovered with the shorter zooms is that when I'm using them on a 5D with the battery grip the weight and bulk of the camera/grip assembly is a great stabiliser
Old 10-11-2006, 11:15 AM   #11 (permalink)
Re: Impact of IS
Thanks for that, I guess that since you're using a FF camera you haven't got to worry so much about keeping the shutter speed up as much as us 1.6 crop folks!
Old 10-11-2006, 11:17 AM   #12 (permalink)
Radiohead's Avatar
Re: Impact of IS
Old 10-11-2006, 1:23 PM   #13 (permalink)
Re: Impact of IS
Originally Posted by Radiohead View Post
Well since they say that to get a sharp image you should aim for a shutter speed of about 1/focal length, I guess you can hand hold without IS switched on more often when using a FF camera (i.e. shorter overall focal length than a crop camera).
Just trying to understand why someone wouldn't use IS when hand held really.
Old 10-11-2006, 1:41 PM   #14 (permalink)
Radiohead's Avatar
Re: Impact of IS
One thing to bear in mind when thinking about crops and FF's:
The focal length never actually changes, just the field of view. So a 50mm lens on a Canon 5D is 50mm focal length, and is 50mm focal length on a 30D/ BUT, on the 30D you're only using part of the lens which gives you a FF equivalent field of view 80mm. Thus, it's as if you were looking through an 80mm lens on a 5D, but the focal length isn't changing. The same effect can be had by cropping a 5D's 50mm image down to what you would see were it an 80mm.
Does that make sense.
Old 10-11-2006, 1:58 PM   #15 (permalink)
Re: Impact of IS
That makes perfect sense, thanks.
So are you saying that at 50mm on a 1.6x crop body, I should aim for 1/50 or 1/80 sec?
impact
