Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 24th at 10:30pm and include delivery.
Help with Filters Hrochnick Digital Photography General Chat 3 09-08-2005 8:54 AM
Filters SGH42 Digital Photography General Chat 4 05-08-2003 3:30 PM
Filters? eXistenZ Projectors 3 10-01-2003 12:18 AM
Filters petrolhead Projectors 4 24-12-2002 7:28 PM
Who's got better filters for less? S. Bush Camcorders and Video Editing 0 02-11-2002 2:57 AM
Old 08-11-2006, 5:22 PM   #1 (permalink)
Conspicuous Member
stevegreen's Avatar
Thanks: Gave 1,143, Got 1,013
Filters......
I have decided that I need to get some filters to fit my 350D.
I have been looking at both Cokin and Hoya filters but don't really know which to go for.
I will be initially looking at a Circular Polarizer and maybe some graduated filters.
The Cokin range looks good and I assume that I would be looking at the P series for my lenses (77mm threads on both the 10-20 Sigma and the 24-105 Canon) One thing that concerns me slightly at the moment is vingetting at 10mm. Will the Cokin range suffer from this? I'm assuming that a screw in filter wouldn't.......but they are soooooooo expensive!
Any advice/alternative suggestions appreciated.
EOS 5D Classic~EF 24-70mm f/2.8L~EF 70-200mm f/2.8L IS~EF 50mm f/1.4~580EXII
Flickr Website Blog
stevegreen is offline   Reply With Quote
Old 08-11-2006, 5:50 PM   #2 (permalink)
Kaoshan's Avatar
Thanks: Gave 8, Got 20
Re: Filters......
I recently got a 77mm Hoya Circular Polariser as it fits all my L lenses. It produces some very nice effects. The only problem I have with it is that it is difficult to adjust with a lens hood mounted.
I'm also looking at graduated filters.
Canon EF 28-135mm f3.5-5.6 IS USM lens for sale.
Kaoshan is offline   Reply With Quote
Old 08-11-2006, 7:40 PM   #3 (permalink)
Dar
Dar's Avatar
Thanks: Gave 15, Got 6
Re: Filters......
You can still get vignetting from a screw in filter. I have a 77mm circular polariser which covers all my lenses. I have been looking at the Cokin P series as I would like to get a graduated filter.
The only complaints I have heard about the Cokin system is light leaking in as the filter isn't a tight fit in the holder.
Dar is offline   Reply With Quote
Old 09-11-2006, 11:44 AM   #4 (permalink)
Nick Cartwright's Avatar
Thanks: Gave 13, Got 3
Re: Filters......
I believe Cokin do a 'Wideangle' holder for the P system. I think it is lower profile to avoid vignetting on wide angle lenses.
Nick
Nick Cartwright is offline   Reply With Quote
Old 09-11-2006, 12:03 PM   #5 (permalink)
Kaoshan's Avatar
Re: Filters......
You can still get vignetting from a screw in filter...
How right you are! This is the first sunny day here for a while so I've been out with an assortment of lenses and the circular polarising filter. Vignetting is most noticable on the 24-105 L at 24mm (This is on a 5D body)
Old 09-11-2006, 12:17 PM   #6 (permalink)
h4rri's Avatar
Thanks: Gave 37, Got 175
Re: Filters......
You would need a wide holder for the 10-22, the normal one cuts in around 16mm.
I would recommend the Cokin system, definatelly a good buy. I found Hilton Photographic to be the best buy, on eBay. Let me know if you need their eBay id
w: www.randomphotos.net
#: Canon 1D Mk III - Bunch of Lenses. Bag full of other stuff :#
h4rri is offline   Reply With Quote
Old 09-11-2006, 12:19 PM   #7 (permalink)
Conspicuous Member
stevegreen's Avatar
Re: Filters......
Thanks for the replies.
I have just been into the local Jessops and the helpful chap behind the counter said that their own 'Pro' brand of circular polarisers are on 1/2 price offer at the moment and that they are as good quality as the Hoya brand (in fact he said they were the same apart from the branding) I asked him about vignetting at 10mm (16mm equivalent) and he said that the profile of the surrounds was quite shallow so I shouldn't see much vignetting at 10mm (16mm) Kaoshans post would suggest otherwise.
£53 for a 77mm thread circular polariser, Jessops brand, seems quite tempting but I wonder if the quality is the same or whether there would actually be that much in it if there were a difference. I had a look at the quality of a Jessops UV filter and it seemed to be quite good.
Flickr Website Blog
Old 09-11-2006, 12:25 PM   #8 (permalink)
Thanks: Gave 23, Got 40
Re: Filters......
That's interesting to know - I'm going to pop in to our Jessop's at lunchtime to have a look...
You only really see bad vignetting if your aperture is open wide (i.e. low aperture value) - I've got a 5D, and a Hoya UV filter on my 16-35, and don't get too bad vignetting. It's mostly noticeable if you've got a constant colour scene - e.g. sky, snow, painted wall, etc.
My Flickr stream
Chunder is offline   Reply With Quote
Old 09-11-2006, 12:40 PM   #9 (permalink)
h4rri's Avatar
Re: Filters......
Got a few of their filters and they are good quality
The Cokin cost me £9 for the holder [same again for the wide one] and £6 for the ring adaptors then about £12 a filter Very flexible and I'd say moreso than a standard screw on filter.
Old 09-11-2006, 3:31 PM   #10 (permalink)
Kaoshan's Avatar
Re: Filters......
Steve,
With the 24-105 L + cpf on either a 350D or a 30D there is no vignetting at 24mm. It only occurs on a FF body.
Old 09-11-2006, 3:35 PM   #11 (permalink)
h4rri's Avatar
Re: Filters......
Originally Posted by Kaoshan View Post
Steve,
But there would be on the 10-22mm bud
Old 10-11-2006, 9:25 AM   #12 (permalink)
Re: Filters......
Even though the 10-22 is an ef-s lens, so the sensor doesn't actually gather any (well, much) light from the edges of the lens?
My Flickr stream
Old 10-11-2006, 9:35 AM   #13 (permalink)
h4rri's Avatar
Re: Filters......
Yeah thought that would be a factor but it isn't
Old 19-11-2006, 11:23 PM   #14 (permalink)
Thanks: Gave 18, Got 28
Re: Filters......
has anyone got any photos taken with the cokin circular polariser?
Im also looking for a polariser but worried about the cokins quality.
cheers
spanna is offline   Reply With Quote
Old 23-11-2006, 12:14 PM   #15 (permalink)
Re: Filters......
well ive been advised by a collage photography teacher to go with the lee filter system.
Does anyone use them or have experience of them?
filters
