Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 24th at 5:30pm and include delivery.
PC to Macbook??? greavsy69 Computer Systems 12 17-12-2006 9:07 PM
macbook- anyone know anywhere that does 0% Dominic85 Computer Systems 1 18-10-2006 11:52 AM
Calibrating a Display for HD-DVD Geesus Blu-ray Players 8 16-09-2006 3:06 PM
MacBook memory fruvos Hard Drives and Memory - RAM/Cards and Sticks 6 20-07-2006 8:20 PM
Old 07-11-2006, 7:39 PM   #1 (permalink)
grantsteve's Avatar
Thanks: Gave 247, Got 147
Calibrating Macbook display
... a bit off topic I know, but its something I noticed whilst viewing / editing photographs so here goes ...
I think I need to tweak the settings on my Macbook display for two reasons really. Firstly, when I was looking at some of the comp entries at lunchime on my work PC the colours looked really punchy. Looking at the same photograph on my Mac at home the colours are dull and washed out.
Secondly, when I edit photographs (levels, saturation etc.) according to my tastes on my Mac they often come back from the printers way off. I know this could be down to my choice of printer and other variables but (a) I use Photobox and thought they had a good rep for image quality; and (b) I thought that if they image came to them edited then they left it alone and didn't do any adjusting.
Can anyone offer any guidance with this please? ... I'm hoping its going to be as easy as downloading a display profile from Apple
My Flickr
Nikon D80 + Grip | Tokina 12-24mm f4 | Sigma 24-70mm f2.8 | Nikkor 70-300mm f4.5-5.6 VR | Nikkor 50mm f1.8D | Nikon SB600 Speedlight | Giottos MT9250 & MH 7303-730 | Ricoh GX100 | Lowepro Mini Trekker AW
grantsteve is offline   Reply With Quote
Old 07-11-2006, 8:04 PM   #2 (permalink)
Thanks: Gave 3, Got 29
Re: Calibrating Macbook display
I take it you've used the Apple Display Calibrator in System Prefs?
I must confess that on TFT's at least, i've had very good results using it, and my prints from Photobox edited from RAW in CS2 came back pretty much spot on.
Panasonic TH42PZ70 - Xbox 360
Macbook 2ghz
chris1210 is offline   Reply With Quote
Old 07-11-2006, 8:43 PM   #3 (permalink)
grantsteve's Avatar
I have, but previously only using the basic method. I've just tried the advanced version and it allows a lot more tweaking to suit my eye, and the results seem a bit better.
I guess the TFT at work and the LCD on the Mac could account for a difference too.
Photoshop says the images from my camera (D50) have a sRGB colour profile. Is there anyway I can get my screen to display this accurately (i.e. as the camera has captured it)?
My Flickr
Old 07-11-2006, 11:34 PM   #4 (permalink)
Thanks: Gave 12, Got 15
I use mac displays at work and home (30" + 23" cinema displays) and a macbook and macbook pro.
I would not calibrate your display for sRGB but at the standard for photographic work, their is a lot of discussion as to what to set it too. but the main options are
these are for macs
5000K 1.8gamma 120 luminance for LCD
or
6500K 2.2gamma 120 luminance for LCD
the luminance is 100 for crt
the gamma is also a talking point as the mac gamma used to be 1.8 but all the info i keep finding says use 2.2 as it changed a while ago
our monitors are calibrated 5000K 1.8 at work
I use 6500K 2.2 120 on my mac
i have tried photos calibrated on one system and moved them to the other and you dont see any discernable diffrence, you will if you change profiles on your machine one after the other, as your eyes get used to the differing white balance.
I also use photobox and my prints are spot on using
6500K 2.2 gamma 120 luminance
set it up with the mac utility on advanced you should be fairly close with that.
Mark
Canon Stuff.
HCking is offline   Reply With Quote
grantsteve (08-11-2006)
Old 08-11-2006, 10:03 AM   #5 (permalink)
tomson's Avatar
Thanks: Gave 61, Got 163
I also use 2.2 gamma/ 6500k (on a cinema display, imac and powerbook) and get pretty consistent results.
tomson is offline   Reply With Quote
Old 08-11-2006, 7:06 PM   #6 (permalink)
grantsteve's Avatar
Ok chaps, having read your posts at work I thought it made sense and it would be easy to change the settings when I got home... not the case though
Any chance one of you would be good enough to do me a quick dummies guide?!
I get to the bit where I open up display prefs and choose the colour tab, but then it wants to run me through the calibration thing again. I thought I could enter the settings manually ....?
My Flickr
Old 08-11-2006, 7:13 PM   #7 (permalink)
yes you have to do the full calibration again in advanced mode and put those setting in when it prompts you.
Or if you have a colour calibration system use that with those values.
leave your lcd on for approx 30-45 mins before doing the calibration so the screen has time to get up to its normal working temp.
Then you should be good to go.
Canon Stuff.
Old 08-11-2006, 7:27 PM   #8 (permalink)
grantsteve's Avatar
Cheers ... last question, I hope!
Where do I specify the luminance? I've done WB and gamma and now its on to naming and saving etc. No mention of luminance.
My Flickr
Old 08-11-2006, 10:27 PM   #9 (permalink)
Ah, yes you can't you need an external calibrator to do it, but the factory default brightness setting should be around 120 as that is the standard.
Canon Stuff.
calibrating, display, macbook
