Funny you should say that.
I originally purchased the 2x Kenko last Tuesday.
Got it home took it to a wildlife sanctury a few mins from my house and found that I had no autofocus at all.
The 2x convertor really works fantastic though taking my 400mm to very close to 800mm
Got some great close ups of swans, geese doves etc.
Anyway I read the paperwork whcih said that the 2x needs an aperture of 2.8 for autofocus but 1.4x only needs F4.
I exchanged yesterday and although I get some autofocus it is not consistent enough.
Once it is fitted I can't get wider than F6.3 at 100mm (140mm converted) even if pointing it at the sun!!
At 400mm (560mm converted) its more like F8.
Bummer really. I thought it may be electrical contacts.
If you read the Kenko paperwork I think they are really meant for prime lenses over 100mm not zooms.
I will try and find out a bit more from Kenko if I can.
