Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 22nd at 8:30am and include delivery.
Old 04-07-2006, 2:18 PM   #1 (permalink)
Nick Cartwright's Avatar
Thanks: Gave 13, Got 3
Raw V JPEG
Being new to DSLR cameras I began shooting all my pictures in the highest quality JPEG. However, I recently started to shoot in RAW and I like the fact I can change the colour temperature and exposure on photos I like, but didn’t get these setting right on the camera. .
I’ve started to shoot all photos in RAW, so I can make these adjustments if I haven’t got it right in the camera. However, apart from having to convert every Raw file to JPEG, Are there any other downsides to using RAW?
I have a 1Gig and a 2 Gig CF card so I’m not bothered about the space on these.
Nick
Nick Cartwright is offline   Reply With Quote
Old 04-07-2006, 2:44 PM   #2 (permalink)
wabbitt's Avatar
Thanks: Gave 160, Got 116
Well you've already mentioned the benefits.
The only big downside is the amount of space the file takes up and the time it takes to process the image afterwards.
Apart from that, the RAW file is the best method of capturing your image.
I still think it's better to capture the image right in the camera first and shoot as JPEG. I know it takes practice, and checking histograms, etc. but it makes you a better photographer if you get this right first off. Especially if you are working with lots of images rather than just a few at a time.
OK... I'm boring myself now...
wabbitt is offline   Reply With Quote
Old 04-07-2006, 2:45 PM   #3 (permalink)
geofftelforduk's Avatar
Thanks: Gave 63, Got 153
For me one of the biggest disadvantages is the time it takes to get them all processed (depending on how fussy you are off course) and converted to JPG/TIFF!!
Apart from that they have been a lifesaver on a couple of occasions!!
Canon 5D MKII + grip & 5D MKI + grip | Canon 20D | Canon 17-40 F4L | Canon 24-105 F4L IS | Canon 70-200 F4L IS | Canon 50mm f1.4 | Canon 580EX | Manfrotto 055PROB Tripod & 486RC2 Head | Canon HF100 HD Camcorder
Blog
geofftelforduk is offline   Reply With Quote
Old 04-07-2006, 3:53 PM   #4 (permalink)
Bristol Pete's Avatar
Thanks: Gave 679, Got 340
Personally, I have noted that RAW converted to TIFF and then jpeg retains more detail than a shot jpeg. You cab print TIFF too.
However, if I am shooting a lot of stuff then yes, jpeg is the only answer or shoot both but then you are talking about serious memory.
Bristol Pete is offline   Reply With Quote
Old 04-07-2006, 4:38 PM   #5 (permalink)
tomson's Avatar
Thanks: Gave 61, Got 163
I always shoot raw - batch processing the good ones to psd before tweaking them doesn't take too long. The main downside for me is storage space and archiving - must have several hundred gigabytes worth of images now and I'm not quite sure what to do with them.
tomson is offline   Reply With Quote
Old 04-07-2006, 6:11 PM   #6 (permalink)
Thanks: Gave 74, Got 326
You dont know what you have started with this question.
Dave
Gallery@ http://davepearce.smugmug.com | My S90 images @ flickr
Videos@ http://www.vimeo.com/davepearce/videos
dave_bass5 is offline   Reply With Quote
Old 05-07-2006, 11:33 AM   #7 (permalink)
I was glad I was shooting in Raw yesterday, had a lod of under exposed pictures of my new baby daughter whioch I managed to rescue. I think shooting against a bright, flowery duvet cover played havock with the exposure.
Nick
Old 05-07-2006, 2:07 PM   #8 (permalink)
Thanks: Gave 46, Got 44
A good discussion happened here
http://mezzoblue.com/archives/2006/05/16/raw/
Panasonic TH-37PX70, WD TV Live, Toshiba HD-EP30, PS3, Squeezebox 3, Denon AVR-2805, KEF Coda 9, Kef Model 90C, Eltax HT-2
probedb is online now   Reply With Quote
Old 05-07-2006, 9:39 PM   #9 (permalink)
Thanks: Gave 425, Got 2,078
If you can afford the space : you can shoot raw+ jpeg. ( Such as is possible in Canon 350-30D) Best of both worlds, really
If you like the jpegs you are sorted:if not Raw comes to the rescue ( albeit with processing time)
If you only rely on Raw it can make you a tad less proficient with maximising your ability to take excellent jpeg pics .
Also due to time involves in tweaking some pics will never see the light of day.
Lastly.TBH some pics dont need to start life as RAW as they will at best be used in emails or webpages so the extra PQ / detail may not have been needed the first place
Oh.... Nick: As good as raw is, if you ever have to convert a large no you will realise how consequetial the time taken is: As yo hone in your RAW skills also try to take well exposed jpegs and use RAW ( +/- jpeg) for those critical shots
senu is offline   Reply With Quote
Old 05-07-2006, 9:57 PM   #10 (permalink)
Radiohead's Avatar
Thanks: Gave 289, Got 425
RAW every time. I see little point in spending thousands on bodies and glass, and then not maximising the detail and resolution of the image I capture. I can see whether the shot is a keeper or not regardless of capture format. For me it's the same concept as shooting Adobe RGB rather than sRGB.
Use a fast converter like RSP and, IMO, the time issues of even large scale conversions aren't so much of an issue. My last wedding saw me come home with 1400 images, swiftly edited down to 350 1st choices - RSP converted these to JPG in less than 1 hour. Just because you shoot RAW doesn't mean you're any less careful at getting the image right in capture in the first place.
At the end of the day though - shoot what's right for you, and you alone.
"All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon
Radiohead is offline   Reply With Quote
Old 05-07-2006, 10:23 PM   #11 (permalink)
Thanks: Gave 211, Got 328
I shoot RAW + Jpeg - Using the jpeg only as a proof.
So, when you really want to enhance that "good one" - you have the RAW file.
And as you have the jpeg, there's no need to convert every RAW file for standard viewing/browsing.
springtide is offline   Reply With Quote
Old 06-07-2006, 8:46 AM   #12 (permalink)
At the moment I'm using the Olympus software to convert the Raw files. It doesn't take too long,, but transfering from the camera takes a while. I think I read somewhere that the Olympus E-500 is only USB 1.0!!!!
I think there is a batch option in the software too.
I'll set camera to RAW + JPEG tonight and see how much extra space it eats on the card.
Nick
Old 06-07-2006, 9:08 AM   #13 (permalink)
For me its a speed thing
I agree 100% with Radiohead
The way i look at it is that what ever i shoot im going to PP it. not much but maybe just tweak the levels and WB if its off (im not that good at shooting yet). Most of my better shots end up on smugmug so they all get reduced to 800x532 @ 72dpi and then sharpened by me as its better than letting smugmug do it.
For me its much quicker to use C1 as it has a very fast browser, it allows you to correct many shots at the same time, lets you apply the same WB, levels sharpness etc to many shots with just a couple of clicks. It also means im keeping the quality slightly higher untill final output to .jpg or .tif
while im not saying shooting .jpg wont get you the quality for me its the speed of the workflow that pushes me to RAW, plus the fact that you can adjust the exposure without loosing too much IQ IMHO
I do see a lot of shots posted on the net that really should have some PP. they are under exposed, soft, WB way out etc so if your going to do it i dont think shooting RAW will really slow you down (quite the oposite), again IMHO
of course we all have our own way of working and this is mine.
Dave
Old 06-07-2006, 10:29 PM   #14 (permalink)
It will take sort of double.. Do not use you camera to transfer images very fast usb2 card readers abound for under £20. Much faster and you save battery life too. If you are like me you will also be a lot less anxious to install capture software on each PC you need to capture the images on.
I certaily agree that every RAW image has the potential advantage of being the best quality image you can get off the camera. But it is time and skill dependent to an extent .
Until you get to be a dab hand at quickly converting after tweaking I would not abandon Jpeg so quickly for " instant gratification" ,
In the interim the jpeg + raw option allows gentle easing you into the world of " RAW photophiles"
Old 06-07-2006, 10:44 PM   #15 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
I can understand Radioheads sentiment, but also Senu's pragmatic approach.
On a properly exposed image, how much more measureable detail is there in a RAW compared to JPEG image? Not much I'd wager.
RAW obviously comes into its own if you need to tweak things, so Large+RAW as insurance may be useful, or for critical/paid for shots. I should try especially for indoor shots where the WB is often off
But I don't see the advantage for properly taken shots, and I do try to avoid too much PP (I already take ages on a big trip where I've taken 1,000+ images)
richard plumb is offline   Reply With Quote
jpeg, raw
