31-05-2006, 9:10 PM
#1 (permalink)
| | Member
Thanks: Gave 125, Got 59 | Frame / Border help needed
I've just been out having a play with the macro on my sigma lens. I've taken what I think is a quirky shot. a little bit of smart sharpen in cs2 works well, but I also feel that it would benefit from some sort of frame.
My knowledge only extends to using the stroke tool for borders. I've seen some people use some really effective frames on here. Does anyone have a suggestion for this picture? feel free to edit it all you like, just so long as you let me know how you did it since im hoping to use this as a learning experience. http://img180.imageshack.us/img180/3...geshack0lk.jpg
I've I've also hosted another version here http://pmsonic.zoto.com/user/image_d...date-desc/0-30
31-05-2006, 9:25 PM
#2 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 857 |
What is it?
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
31-05-2006, 9:33 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 6, Got 22 |
i recon its pealing plasticote/hammerite on some old railings
Can you keep your signatures appropriate for a family forum please..
31-05-2006, 9:36 PM
#4 (permalink)
| | Member
Its part of a fence that's rusted over years of neglect. I went out to take some crowd shots at murrayfield and ended up taking this as I walked home.
to get a better impression heres a couple of others I took at the same time, although I dont think they worked out very well at all. The first one is no where near sharp enough. http://img251.imageshack.us/img251/5...1resize0pa.jpg http://img257.imageshack.us/img257/9...5resize4tw.jpg
31-05-2006, 9:39 PM
#5 (permalink)
| | Member
Thanks: Gave 125, Got 59 | Quote: |
| Yep, spot on
31-05-2006, 10:22 PM
#6 (permalink)
| | Senior Member
my border is applied by adding a 3 pixel white keyline using the canvas size tool (+3pixels) and then adding a further 47pixels of black around the image using the same method. easy and does the job
31-05-2006, 10:42 PM
#8 (permalink)
| | Member
Thanks: Gave 4, Got 34 | Quote: |
Originally Posted by PmSonic Its part of a fence that's rusted over years of neglect. I went out to take some crowd shots at murrayfield and ended up taking this as I walked home.
to get a better impression heres a couple of others I took at the same time, although I dont think they worked out very well at all. The first one is no where near sharp enough. http://img251.imageshack.us/img251/5...1resize0pa.jpg | Was it handheld? Exif shows it at 1/40, might explain why it's a little soft.
K.
01-06-2006, 6:12 AM
#9 (permalink)
| | Member
K.
| Yep, handheld, braced as much as I could, but not enough. I really needed to have the tripod with me for that one.
Thanks for those links Kavster, I'll check them out properly tonight at first glance they look good.
01-06-2006, 9:36 AM
#10 (permalink)
| | Member
Thanks: Gave 48, Got 24 | Blurred borders
If you look at this thread the 3rd post gives info on blurred borders A walk on Ilkley Moor
Ray
__________________ Kit: EOS 5D, EOS 5. Lenses: EF17-40 f4 L, EF24-105 f4L, EF70-200 f4L, EF100 f2.8 USM],EF100-300 USM, EF28-85 USM, ExtenderII 1.4TC. My flickr |
01-06-2006, 9:52 AM
#11 (permalink)
| | Member
thanks, i'll have a look
01-06-2006, 1:25 PM
#12 (permalink)
| | Conspicuous Member
Thanks: Gave 1,143, Got 1,013 |
I have broken the [img] tags as the pictures piosted are well above the forum limit for embedded images. They need to be sub 200kb.
__________________ EOS 5D Classic~EF 24-70mm f/2.8L~EF 70-200mm f/2.8L IS~EF 50mm f/1.4~580EXII Flickr Website Blog |
01-06-2006, 1:48 PM
#13 (permalink)
| | Member
Thanks: Gave 125, Got 59 |  sorry forgot about the file size rule for a moment there, to be fair they were almost there. resized to 800 x 600 |
