Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Canon EOS 450D Black
Panasonic Lumix DMC-FZ38 Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Nikon D90 Black
Canon Digital IXUS 100 IS Silver
 More...Prices updated November 21st at 11:30pm and include delivery.
Old 20-03-2006, 7:56 AM   #1 (permalink)
Tumbletown
Posts: n/a
CF card format query
I have a new Canon EOS 20D with SanDisk 1.0GB Ultra II CF card. After taking a few experimental shots I re-formatted the card via the camera and now the INFO panel on the camera tells me the card's volume is only 964Mb. Of course my total picture taking capacity has dropped from about 270 to 239 as a reduction of the 40 Megs or so. Is this a fault with the card or is it normal? Some advice would be much appreciated.
Adrian
Old 20-03-2006, 9:10 AM   #2 (permalink)
Thanks: Gave 342, Got 509
Often new cf cards will come with some bundled software saved onto the card. You wont be able to see it on the camera and you can probably only get at it if you use a card reader instad of using the camera's USB connection but that would be my guess for the reduced storage space.
Chris. Serial Procrastinator.
EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky
T0MAT01 is offline   Reply With Quote
Old 20-03-2006, 9:15 AM   #3 (permalink)
Thanks: Gave 35, Got 29
What Tumbletown said....
I might add that with some Sandisk cards, you get a free "file recovery" utility on the card ("File Rescue" or some such name), which could prove VERY useful if you ever have an "accident" with your CF cards, so you might want to check for it using a card reader.
md644 is offline   Reply With Quote
Old 20-03-2006, 9:20 AM   #4 (permalink)
Zone's Avatar
Thanks: Gave 347, Got 558
I'd also check at what quality you have your (presumably) jpeg settings set at as Large/Fine equates to 3.6MB per capture according to steves digicams.
Si
AV Forums "Photo Competition" can be found HERE
Octobers's Photo Competition thumbnail Page HERE
All opinions are mine! (unless I'm told otherwise)
Zone is offline   Reply With Quote
Old 20-03-2006, 11:12 AM   #5 (permalink)
Tumbletown
Posts: n/a
Thank you all for your replies. I've just been contacted by a colleague who has directed me to several web sites about this 'problem'. It appears to be simply the difference between card manufacturers specs (1MB = 1,000,000 bytes) while operating systems use the binary system (1MB = 1,048,576 Bytes). Also the unformatted capacity and formatted capacity are different due to the way the latter is calculated by cylinders/heads/sectors and bytes per track. All interesting stuff but at least I don't have a fault!
card, format, query
