17-03-2006, 6:28 PM
#1 (permalink)
Thanks: Gave 124, Got 64
Monitor calibration
Does anyone use any monitor calibration systems and what have your experiences been?
Just take it as read that I spend too much on gadgets and gizmos
17-03-2006, 11:57 PM
#2 (permalink)
Thanks: Gave 107, Got 271
for a pc monitor?
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (Silverstone case, IMON, Tosh HDDVD-ROM, E2200@2.5GHz, 4670 ultimate, 3GB, 80GB 2.5" drive, Sweetspot SDI card,Happauge HVR4000, Win 7 Enterprise), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
18-03-2006, 6:42 AM
#3 (permalink)
Yup - seems to be coming down in price a lot and I wondered what sort of difference it makes.
18-03-2006, 9:12 AM
#4 (permalink)
Thanks: Gave 342, Got 509
Chris. Serial Procrastinator.
EOS 40D + Grip, 24-105/4 L IS, 70-200/4 L IS, 10-22, 85/1.8, 50/1.8, 30/1.4, Kenko extension tubes, Speedlite 430EX - clicky
18-03-2006, 10:24 AM
#5 (permalink)
Thanks: Gave 21, Got 39
Proper calibration is often overlooked, but is VERY important if you want to edit photographs correctly...
18-03-2006, 10:52 AM
#6 (permalink)
I used Spyder2 for a short while but was not happy with it........sold it and bought Gretagmacbeth Eye One
21-03-2006, 8:42 AM
#7 (permalink)
Thanks guys - I want to shoot in RAW to get the best out of my images so monitor calibration seems sensible. I just don't want to pay a fortune for it!
21-03-2006, 3:44 PM
#8 (permalink)
Thanks: Gave 46, Got 514
How do they compare?
Q: What do you get if you cross an anopheles mosquito with a mountain goat?
A: Don't be silly, you can't cross a vector with a scaler.
21-03-2006, 5:13 PM
#9 (permalink)
For me the Eye One gives me more control than Spyder did.
21-03-2006, 9:03 PM
#10 (permalink)
Thanks: Gave 302, Got 1,052
How much you spend really depends on your monitor. The better calibration tools rely on being able to adjust monitor settings in what they call pre-calibration. To do this you need to be able to set the colour temperature, and adjust contrast, brightness and the RGB settings individually.
If you can't do that and only have fixed colour temp settings then to be honest you may as well go for a cheaper calibration tool as you won't be able to use many of the features of the more expensive models. It's much better to be able to use pre-cal to adjust your monitor as that means the software won't have to mess around quite so much with your video card settings and it's LUT.
My monitor falls into this category so I went for the ColorPlus cheap and cheerful. It works perfectly well for me!!
If you want to edit pictures and want them to stand a chance of looking either half decent on someone else's PC, or want to get close to an accurate print, you simply MUST use a hardware calibration tool.
Ian.
21-03-2006, 9:10 PM
#11 (permalink)
One thing that I have learnt is not to trust my Kelvin pre-sets on my MultiSync LCD 2080UX+.
For the Eye One to calibrate to find 6500K my pre-set has to be set to approx 7100K.
