Ok, I now have a number of shots I really believe are good. They certainly are much better than I have been able to produce in the past but I have two problems......
First, they are printing out a little too dark. Short of buying a colour printer profiling system or making the picture a little over bright in Photoshop I really have no idea how to correct this....
Second is post editing to get the most out of the picture.
One of the pictures I very much like is this one...
Obviously I am working on a Tiff (16bit) created from the original RAW shot.
Now for a more striking intimate image I have cropped around the face and only included the bottom 1/3 of the hair. I very much like this framing so am going to go with that.
Using the healing brush will remove most of the skin blemishes along with noise -> despeckle. Now I have a problem. I feel that a lot of the beauty is detracted from by the bags under the eyes.....
Now I have been all over and tried to find a tutorial on how best to deal with this whilst allowing this close in crop and still making the amendment seem pretty transparent to a viewer. Last months Digital Photographer Monthly had a article on doing just this but it was for Paint Shop Pro. Ok no big deal, I was able to amend the details to the Photoshop CS2 tools and although it did what it said on the tin I couldn't help thinking that it just looked like the area was blurred (which is exactly what the fix was). Even looking closely at the after picture in the magazine highlighted that this was not a perfect fix.
The problem as I see it is trying to remove the bags without loosing texture. I can smooth the area but the loose the detail and have to carry it over to the rest of the face making the portrait look more like one of Barbie that a real person. I have tried selecting around the area, copying the selection to a new layer, lightening the new layer and smoothing it out then setting the transparency to around 38% allowing some of the detail to come through which is probably the best effect yet but there is still the bottom outline of the bag under the models left eye which is so well defined that the shadow comes through the second layer all be it not as pronounced.
The other issue is eye lashes and the edge of the bottom eyelid. I would like to keep the dark edge as created with a dark eye lining pencil when the model applied her makeup. I cannot find a way to get CS2 to select the area of the bottom lid but not the markedly different darkness of the eye lashes and copying the area to another layer and then using the eraser to allow the lashes to come through the colour change to remove the bag just looks wrong. Conversely creating a layer and removing everything apart from the lashes and putting that layer on top also looks wrong.
There must be ways of doing this better.
Anyone care to give instruction for better results ?
Oh and yes I am aware that there are loads of tutorials out there and in part that is an issue in itself. Needle in haystack and wheat from chaff are two phrases that sprung to mind yesterday when searching all day yesterday. The ones I did find seemed to just be quick fixes rather than detailed tutorials to produce professional results.
RB
