Go Back   AVForums.com > Home Electronics > Digital Photography General Chat
Today's price checkPowered by
Panasonic Lumix DMC-TZ7 Black
Panasonic Lumix DMC-FZ38 Black
Canon EOS 450D Black
Canon PowerShot A480 Silver
Canon EOS 500D Black + 18-55mm Lens Kit
Panasonic Lumix DMC-FS15 Black
Canon EOS 1000D Black + 18-55mm Lens ...
Canon Digital IXUS 100 IS Silver
Nikon D90 Black
 More...Prices updated November 25th at 5:30am and include delivery.
And you thought autofocus was simple.... Johndm Digital Photography General Chat 6 28-08-2005 5:04 PM
Canon 100-400 L.....First Outing Johndm Digital Photography General Chat 101 17-05-2005 5:35 PM
Camera for safari Astaroth Digital Photography General Chat 4 21-03-2005 7:11 PM
AE700 lens shift - the maximums, please? begu Projectors 2 05-10-2004 1:02 PM
Old 15-11-2005, 2:16 PM   #1 (permalink)
Lens recommendations fo 10d - HELP???
Okay guys this is where I need your help. After much soul searching and debating I have purchased a second hand Canon 10d. It doesn't come with a lens. Now, here is the $64m question. I intend to take mostly portrait and sports photographs. Which lenses would you recommend? I was thinking of a 28 - 90 for the portrait (canon MkII) and something like a 100 - 300 for the sports photography (mainly football). Please help with some recommendations.
By the way what about CF cards? 1Gb or 2 x 512mb and whast make?
Paxter is offline   Reply With Quote
Old 15-11-2005, 3:56 PM   #2 (permalink)
tomson's Avatar
Thanks: Gave 61, Got 163
The 28-90mm isn't a great lens at all. If i were you I'd look at a 28-105mm (make sure its the f3.5-4.5 rather than the f4.5-5.6 though). There are plenty used ones on ebay.
tomson is offline   Reply With Quote
Old 15-11-2005, 5:45 PM   #3 (permalink)
RimBlock's Avatar
Thanks: Gave 6, Got 16
What sort of Portrait (face, shoulders & head, waist up, full length) ?
Depends on available space (as I have found out ).
I use a 50mm prime f1.4 for half body shots, a 85mm f1.8 prime for head shots. I also use the 28mm - 135mm IS which I find surprisingly good for this. It is also a great walkabout lens. Examples can be found in my 'sticky' thread on page 2.
Sport usually requires a long fast lens so look for large focal length with a small fx.x number. Others will be able to advise better on this as it is not an area I have much interest in.
Regards
RB
Follow my adventures in photography here.
RimBlock is offline   Reply With Quote
Old 16-11-2005, 10:57 AM   #4 (permalink)
Thanks for the replies. Most of my portraiture will be of the head & shoulders type. I think I will purchase a 50mm prime for this, but my main quandry at the moment (as funds are limited), is, should I go for a 70 - 210 F4-5.6 or should I push the boat out (and the credit card) and go for an f4 throughout... this means buying canons own lens. It's been a while since I used a Sigma lens, but I believe they are quite good at present.... Any views?
Old 16-11-2005, 12:23 PM   #5 (permalink)
RimBlock's Avatar
depending on cash, you can pick up the nifty fifty 50mm f1.8 (i think) for around £60. The 50mm f1.4 I use is around £300. Is the difference worth it...... no idea, have never tried the f1.8 but there are loads of rave reviews of it.
As for the longer length lens I am afraid I cannot help. There are a number of sites out there with lens reviews though.
RB
Old 16-11-2005, 3:27 PM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 859
I can recommend the Sigma 70-200 f2.8 APO HSM...it would be ideal for sports and can be picked up at a good price second-hand on eBay...that's where I got mine.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 17-11-2005, 10:14 AM   #7 (permalink)
What would you call a good price
Old 17-11-2005, 10:30 AM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
Well I bought mine for 275UKP.
As a rough guide expect to pay £270-£330UKP depending on condition.
JayCee
Old 17-11-2005, 11:42 AM   #9 (permalink)
Thanks Jaycee. I will keep my eyes open. I have noticed that some people on ebay are paying more for lenses than you can buy them new. Makes it hard to get a bargain!
Old 25-11-2005, 12:31 PM   #10 (permalink)
Thanks: Gave 32, Got 145
for portraits and still life shots i would wholeheartedly recommend the sigma 24-70 DX 2.8 lens, its fairly bulky but stopped at 5.6 or smaller its pin sharp and almost no chromatic abberations. new they are 300 on the net about 230, a superb all round lens my friend good luck
ush flynn is offline   Reply With Quote
10d, lens, recommendations
