05-11-2009, 1:33 PM
#1 (permalink)
| | Member
Thanks: Gave 33, Got 3 | Recommend A Lens Seller
another favour is possible !
Following from a previous thread of mine to buy a new lens for my canon 400d, been trying to get hold of recommended camera guy Kerso (both email, and ebay message a seller) but still no joy yet.
In that respect can anyone recommend a reputable seller with competitive prices - either a e-retailer or direct seller.
Cheers.
05-11-2009, 1:47 PM
#2 (permalink)
| | Member
Thanks: Gave 33, Got 3 | re: Recommend A Lens Seller
Mod - please change title to 'Recommend a lens seller'
cheers
05-11-2009, 1:56 PM
#3 (permalink)
| | Prominent Member
Thanks: Gave 1,025, Got 885 | re: Recommend A Lens Seller
Hello there
What Lens are you after and would you buy 2nd hand.
Cheers Holo
Canon 40d, Canon 400d, Tamron 17-50mm f/2.8, Canon 50mm f/1.8,Sigma 70-200mm f/2.8, Canon 100mm f/2 Sigma 100-300 f4 Canon 430EX Speedlite
05-11-2009, 2:05 PM
#4 (permalink)
| | Member
Thanks: Gave 33, Got 3 | re: Recommend A Lens Seller Quote:
Cheers Holo   | After Canon EF-S 17-85mm f/4-5.6 IS USM. Would consider 2nd hand tentatively. Would depend on price etc as normal. I am after new if possible to be covered by the guarantee.
05-11-2009, 2:22 PM
#5 (permalink)
| | Prominent Member
Hello there
One here 2nd hand for £249
Or one here new from HK for 280.16
Cheers Holo
06-11-2009, 9:27 AM
#6 (permalink)
| | Member
Thanks: Gave 33, Got 3 | Re: Recommend A Lens Seller Quote:
Cheers Holo   | Thanks Holo. Will definitely conside them. Long shot, but had hoped to shave a few more pounds off a new price.
07-11-2009, 9:20 AM
#7 (permalink)
| | Prominent Member
Thanks: Gave 283, Got 558 | Re: Recommend A Lens Seller Quote:
Originally Posted by taposh After Canon EF-S 17-85mm f/4-5.6 IS USM. Would consider 2nd hand tentatively. Would depend on price etc as normal. I am after new if possible to be covered by the guarantee. | mpb photography give u a 6 month guarantee on their 2nd hand lenses. i got a mint 100mm macro from them.
i'd also look at the highly respected tamron 17-50 2.8 and sigma 17-70 before you get the 17-85IS as the 17-85IS isn't the greatest lens. have a quick search on here
07-11-2009, 10:33 AM
#8 (permalink)
| | Prominent Member
Thanks: Gave 319, Got 1,103 | Re: Recommend A Lens Seller
Give Kerso another try.
He's got various lenses through ebay for immediate delivery. eBay.co.uk Shop – FLASH CAMERA: Search results for.
Sometimes he disppears for a bit, but tends to pop up again.
07-11-2009, 12:42 PM
#9 (permalink)
| | Member
Thanks: Gave 7, Got 8 | Re: Recommend A Lens Seller |
