| Linear or Circular Polarizing filter?
Hi All,
I have a Panasonic LX3, and I've bought a 52mm extension tube so that I can attach filters, (havn't received it yet).
I have an old jessops circular polarizing filter - probably about 15 years old, which I could use, but I was thinking about buying new as I thought the quality of filters may have improved by now?
Anyway, I've done a bit of research and found that my camera will work with the linear type of filter, and advice appears to be that the linears are much better value for money than the circulars.
I want to spend around £20, and I've been searching online.
Ive seen a Kenko circular polarizer for £16.50 incl. delivery, which I think is a very good price as it is actually a Japanese Hoya, and seems to retail elsewhere at around £28.
But, I can't find many linear polarizers under £20. Hoya sells them for £29, and Ive come across a Kood linear filter for £16 incl. delivery. ( Allthough I've had to email the seller of the Kood to check that it will work as the website states that this filter will not work with autofocus cameras. - I think they've put this just because it won't work with most DSLRs )
Anyway, (assuming the linear will work fine,) my question is which should I buy?
Will the linear Kood give better quality results than the circular Kenko?
Or should I stick with my old Jessops?
I'll be most greatfull for anyones thoughts / opinions.
