27-07-2009, 12:23 PM
#1 (permalink)
Thanks: Gave 3, Got 11
New starter - DSLR lense advice
Hi all,
I am about to purchase my first DSLR and am stuck deciding which lense to use.
I have finally decided on the Nikon D60 and with quidco can get it for £330 from Jessops with the 18-55mm VR lens.
I am looking to take a big mixture of shots and instead of buying a second lens (i.e 55-200) I am toying with the idea of buying the Sigma 18-200mm OS lens (currently on hold for me in the local Jessops as its the last one) which is £199 down from £299.
I can also sell the original 18-55mm either on here or eBay etc to help fund the camera.
Its not worth getting body only as the lowest I can find it for is £319 so for an extra £11 I can get it with the lens.
Do you think as a starter to DSLR's that I will benefit having just one lens (the Sigma, which I've read has good reviews) or whether to buy a second lens to accompany the 18-55mm.
Any help and/or guidance appretiated.
Dan
27-07-2009, 5:20 PM
#2 (permalink)
Thanks: Gave 0, Got 2
Re: New starter - DSLR lense advice
Hi Dan,
I bought my D60 with 18-55VR lens from Jesops as well. I managed to get the 55-200VR lens for about £116 on line at simply electronics, I am now after the 50mm f1.8d (currently at £87 via argos!). I don't know much about Sigma lens as I am new to this as yourself. I am sure some of the more experienced members on here will be able to add more constructive comments. However I have learnt already that one lens can't cover all situations. Some members on here recomend the 70-300VR lens (I couldn't justify the price at the time). Also I have seen websites where you can hire lens for special occasions eg: safaris where you may want 400mm + and don't want to pay a fortune!!!!
27-07-2009, 5:26 PM
#3 (permalink)
Also forgot to say I have seen a lot of 18-55VR lens for sale on Ebay, so don't think you will get top price. I find it an excellent lens and will never part with mine. For £116 you can have a 55-200VR lens.......
27-07-2009, 5:45 PM
#4 (permalink)
Thanks: Gave 1, Got 2
I got a 55-200mm lens for my D60, but am now getting a Tamron 70-300mm lens which is only about £170.
I highly recommend the 50mm 1.8, although you can only manual focus on the D60, it's the best lens I own. Argos have long sold out though at that price.
Macbook Pro 2.2ghz, 4GB RAM, 160GB HD, iPhone 3G, Nikon D90 & D60, 18-135mm, 55-200mm, 50mm f/1.8, Sigma 30mm f/1.4
27-07-2009, 8:12 PM
#5 (permalink)
Crazy guy, can you provide a link to the 55-200mm lens you spoke about.
The one I think you mention is the Sigma one currently at £149.95 at Simply Electronics.
Cheers for your reply. Think I'm gonna buy a secondary lens rather that use one.
Regards
28-07-2009, 3:09 PM
#6 (permalink)
Thanks: Gave 30, Got 35
I think Simply Electronics are grey imports aren't they?
28-07-2009, 3:40 PM
#7 (permalink)
Thanks: Gave 425, Got 2,080
Have a read of the SE thread in the camcorders Forum
S3Stuff
Opinions expressed by myself are not necessarily those of AV Forums..or even mine!
28-07-2009, 6:51 PM
#8 (permalink)
Thanks: Gave 6, Got 39
If it were me over again I would hang on to the 18-55 kit lens learn to use the camera and save some dosh, when funds allow buy the 18-200 you will never look back
D40 with 18-55mm kit lens 70-300mm VR Sigma 17-35mm f2.8 Nikon SB400 Flash and Tamrac Expedition 4 bag
29-07-2009, 6:54 AM
#9 (permalink)
I have made my purchase.
Got the D60 w/ 18-55mm VR lens = £330
Sigma 18-200mm OS lens = £190
I have got an absolute bargain with these, especially the Sigma lens which had £100 off in Jessops.
Going to have a play, and if I get on well with the Sigma, will probably look at selling the 18-55mm to help pull me back under my £500 limit.
Reading reviews of the Sigma it looks like I've got a cracking lens, just depends wether I'm comfortable with it always on the camera as its fairly hefty.
If anyone knows of any 55-200mm lenses with IS/OS/VR etc that might sway my decision please post them.
Cheers for your input guys.
29-07-2009, 11:31 PM
#10 (permalink)
Thanks: Gave 12, Got 14
You can get the Nikon 55-200mm VR lens from camerabox for £159.99
Link: Nikon 55-200mm F4-5.6G VR AF-S DX IF-ED
Ive just got a D60 2 weeks ago with the 18-55mm from jessops in store. Then purchased the Nikon 55-200mm VR from there.
EDIT: Just read though your post again do you want an 18-200mm or 55-200mm?
Pioneer 428XD, Pioneer VSX-AX2AS, Pioneer SVLF-II, Sky HD, PS3
30-07-2009, 12:12 PM
#11 (permalink)
Thats the lens I've been looking at but thats a good price thanks.
Its just for me to decide whether I want the 18-55mm VR and 55-200mm VR as you do, or just have one 18-200mm, which is the Sigma one I have.
I just feel the Sigma is too large to have on my camera all the time and think I'll opt for the two lens method. Plus it works out £50 cheaper.
How do you get one with the two lenses, do you find you use one more than the other and do you use a bag that stores the spare or do you just take the relevant lens out.
31-07-2009, 12:41 AM
#12 (permalink)
I have only used the 55-200mm at the moment. I brought the camera for motorsport really. So ill be using the 55-200mm mostly. Have yet to take it anywhere other than Chester Zoo and West Midlands safari park though. Planning on Mallory park this weekend and Silverstone in a few weeks.
However i will be going away at the end of the month for a few days and I think ill be using the 18-55 most of the time. Want to try landscape etc and some long exposures.
The only thing im bothered about with changing the lens is dust. But im sure i just worrying about nothing.
I have kept both lenses with me when ive taken it out just in case, keep one in the bag. (lowepro nova aw 180)
I read about a few lenses when i bought it, was going to go for the 18-200 Nikon. But read about the lens creep. Also i think i read that the two separate lenses were better.
31-07-2009, 8:13 AM
#13 (permalink)
Thanks: Gave 20, Got 63
Sigma 18-200mm OS lens = £190 ...
Good lad! I have that lens on my Canon 400D & love it (paid £296 btw, so you got a real bargain  ).
Don't want to rain on your parade, but it's definitely the OS version, isn't it? There is a non-OS version at about £100 less.
My only caveat is the weight to lug about. For days out on your feet, such as walking around London, it gets a bit wearisome. My solution is the Canon 50mm 1.8 fixed length, which is a super lens weighing practically nothing. I don't think there's a Nikon equivalent, so you might like to hang on to the kit lens for those times.
