Originally Posted by chrishull3
Thanks , i am not sure but if you have yours scanned at 3.5 to 4mp from negative strips which i suppose have the same image resolution as slides i presume that is higher than hd video,i think the quality of the shots may determin the resolution more than the film.
From recollection mounted 126 film was just over 25mm square, on the strips it's 28mm square, so depth wise you have at least a match for 35mm film.
In my case the film hadn't been well looked after, so i drew a line at 4MP, if you have good film i'm sure you'll be able to go higher.
