27-06-2009, 8:01 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 153, Got 56 | Which tripod
Ive been using a cheap tripod for about a year now. I had a look at some in Park cameras a couple of days ago, They feel a lot more solid than the one im using now.
Does anyone have any recommendations? Was thinking around £100. Would it be worth spending more?
It doesn't matter how you find the pot of gold, all that matters is that you beat the leprechauns my_flickr
27-06-2009, 9:26 PM
#2 (permalink)
| | Member
Thanks: Gave 23, Got 118 | Re: Which tripod Quote:
Originally Posted by Baron Von Doom Ive been using a cheap tripod for about a year now. I had a look at some in Park cameras a couple of days ago, They feel a lot more solid than the one im using now.
Does anyone have any recommendations? Was thinking around £100. Would it be worth spending more? | A few months back I picked up my Giottos MTL 9251B with 5001 3 way head for £65 from Amazon. Bargain!
__________________ Sony A700, VG-C70AM, HVL-F58AM, Giottos MTL9251B+MH5001, Sekonic L358, Portaflash 336VM
Sony 50mm f1.4, Sigma 24mm f2.8, Sigma 10-20mm f4-5.6, Tamron 90mm f2.8, Tamron 17-50mm f2.8
Minolta 35-70mm f4, Minolta 70-210mm f4, Minolta 24-85mm f3.5-4.5 |
27-06-2009, 10:06 PM
#3 (permalink)
| | Member
Thanks: Gave 74, Got 42 | Re: Which tripod
From my own research it seems you have to pick between two main features, you either go for complete stability which is often coupled with wiegth and size, or you go for a lightwieght/compact design that isnt as stable. To find a tripod that is both very stable and is light weight is quite diffuclt and requires more than £100. Most tripods come to some sort of compromise balanced more so to one of those two key features. You will have to decide which of the two, stability or portabilty is the more important to you.
In my opinion the point of a tripod is to keep a camera steady during long exposures, a tripod that doesnt provide decent stabilty (despite how portable it may be) is a waste of time as you're still going to get blurred pictures, thus defeating the point of using a tripod at all. However saying that if a tripod is a pain to carry it might dicourage you from taking it out as often. In my case i just put up with it. I bought a decent Tamrac bag and lash a heavy but stable tripod onto it. If im going to make the effor to take a tripod out, i want one that will do its job properly.
__________________ Sony KDL26T3000 - PS3 - Denon AVR-3300 - Jamo A102HCS5 - Sennheiser HD580 - PC (AMD Phenom 9500~Quad Core, X-Fi Fatal1ty Pro, Geforce 8400GS, 3GB Ram, Windows7) - Netbook (Samung NC10, 2Gb ram) - DSLR (Sony A700 - VGC70AM - HVL F42 - Tam 17-50 f2.8 - Min 50 f1.7 - Sony 70-200 f2.8 G) flickr |
28-06-2009, 5:55 AM
#4 (permalink)
| | Prominent Member
Thanks: Gave 373, Got 737 | Re: Which tripod
This subject has been done to death already (use the search function). A lot of us on this forum have the RedSnapper triopd and ballhead. They now have a new 4 section 'pod' for the same price as the 3. TRI-284 and RSH-12 ballhead works very well and is bang on your budget.
Go to TalkPhotography and register there, then order from RedSnapper and say you're a member of TP for a 10% discount (yes, the offer is still available).
28-06-2009, 6:32 PM
#5 (permalink)
| | Member
Thanks: Gave 10, Got 15 | Re: Which tripod
Yes, would agree with Redsnapper, have one and it is excellent
28-06-2009, 6:54 PM
#6 (permalink)
| | New Member
Thanks: Gave 0, Got 1 | Re: Which tripod
Hi folks,
Just a little thought on this 'Which Tripod' topic.
I use a tripod mainly for shooting waterfalls. There are several aspects of shooting waterfalls that influence the heavy/lightweight debate.
1. Waterfalls tend not to be situated next to the car park, at least not in Wales. So a long walk can be expected so a lightweight tripod is needed.
2. I like to shoot waterfalls with long exposures so that the water flows like silk but the rocks and greenery need to stay sharp and therefore a heavy tripod is needed.
I solve this conundrum by carrying a lightweight tripod and an empty 5 litre water bottle. At the waterfall I fill the bottle from the stream and hang it below the tripod head. I leave it a short while for the water to still, set the camera to shoot using the timer (I haven't got a remote) so I dont introduce vibration with my finger and I tend to get sharp exposures.
Of course this trick won't suit all photography but I like saving money given the chance.
Dave |
28-06-2009, 7:25 PM
#7 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 859 | Re: Which tripod Quote:
Originally Posted by djbsom At the waterfall I fill the bottle from the stream and hang it below the tripod head | What a handy tip.
Thanks Dave.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
28-06-2009, 10:16 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 297, Got 173 | Re: Which tripod Quote:
Originally Posted by cambsno Yes, would agree with Redsnapper, have one and it is excellent | Ditto. Well happy with mine |
29-06-2009, 12:57 PM
#9 (permalink)
| | Member
Thanks: Gave 2, Got 25 | Re: Which tripod
consider monopods, too. Much lighter, easy to carry around, very versatile, and unless you shoot loooong exposures, just as good. well ok, nearly, dont want to start a war here.
toad
no signature is the best signature.
