24-07-2008, 5:18 PM
#1 (permalink)
Thanks: Gave 210, Got 114
Nikon D700 in stock
At Jessops. Too much money in my opinion. £1500-00 & I'd have jumped at one.
24-07-2008, 5:22 PM
#2 (permalink)
Thanks: Gave 14, Got 17
Re: Nikon D700 in stock
Im just gonna save some money and buy a D300.
Spend the rest of my money on a lense.
Flickr
24-07-2008, 5:51 PM
#3 (permalink)
Thanks: Gave 245, Got 157
Originally Posted by konastab01
I'm just gonna save some money and buy a D300.
Spend the rest of my money on a lens.
Good choice, I just do not see how or where the D700 fits into the schema of things, it cannot be worth double a D300 or conversely the D300 is an absolute steal and it should be at least £500 more.
If you are going to spend that much then buy a D3.
My Flickr: http://www.flickr.com/photos/25907924@N05/
My gallery: http://www.avforums.com/forums/photo-album/771100-grants-gallery.html
24-07-2008, 5:57 PM
#4 (permalink)
Thanks: Gave 235, Got 340
It seems that Jessops' website doesn't marry up with itself...
clicky
The price will soon drop anyway. It always takes about a couple of months to get to a more reasonable level.
Edit: Ah your link included a lens!
Half the people you know are below average.
EOS 40D + Grip, 24-105 f/4 L IS, 70-200 f/4 L IS, 10-22, 50mm f/1.8 II, Kenko extension tubes, Speedlite 430EX - clicky
24-07-2008, 6:13 PM
#5 (permalink)
clicky
It's still £2000.00 without the lens
My gallery: http://www.avforums.com/forums/showthread.php?t=771100
24-07-2008, 7:31 PM
#6 (permalink)
Thanks: Gave 204, Got 382
£1690 at RGB Tech. Much better. Clearly better for low light work than a D300 and smaller, cheaper and lighter than a D3. Slots right in for me.
"All the technique in the world doesn’t compensate for the inability to notice." - Elliott Erwitt
"It's no good saying "hold it" to a moment in real life." - Lord Snowdon
24-07-2008, 8:06 PM
#7 (permalink)
Thanks: Gave 588, Got 271
The D300 is clearly aimed at the wedding market. Have you not seen the Nikon brochure?
Also, the weight issue over the D3 is a big thing for older people who cant manage the weight. The same applied to the 5D - to me, often mooted as a bumble bee/bottom of the garden camera it found a niche market. I suspect the D700 will as well.
Finally, the D3 hammers the ISO of the D300. Thats a fact. Thus the D700 will be a truly great camera.
Pete.
http://www.titanimages.co.uk/
http://www.flickr.com/photos/bristolpete/sets/
http://petetileytitanimages.blogspot.com/
24-07-2008, 8:28 PM
#8 (permalink)
So ditch the d300 and save up a load of extra pennys to buy the D700.
I take it that it is better for portable photography.Motorsport,bikes,gigs?
Is it just as good as the D3?
Flickr
24-07-2008, 9:08 PM
#10 (permalink)
Thanks: Gave 60, Got 47
D300 may be better for motorsport on a tighter budget, the DX mode gives better reach on your lenses. However the higher ISO would be better for gigs and most everything else.
Ideal world would be a D3 and D300 for me, but then Id have to use em
Samsung PS42P5H : Denon 2910 : Pioneer 2011 : Kef Q5 front : Kef Q9C centre : Kef Q3 rears : MJ Acoustic Ref1 : Arcam CD73 : Sky HD : Flickr
24-07-2008, 9:25 PM
#11 (permalink)
Thanks: Gave 29, Got 81
Well it's a couple of hundred less than double the D300 - so the D300 is better value, but so it should be, it wasn't released this week. In a few months the price difference will be lower.
So the D700 came out this week, so for a while it is not going to be as good value as it will be in a few months. And even so, can you buy a D3 in the UK for within £1000 of a D700? That £1000 is a lot to most of us.
50" Pio MXE1, SkyHD, SDI DV89, Lum HDP/SDI, Merid 561, Bluesky 6.5s & 5s, Velodyne SPL 1200 II, 360. Sq box II x5, TAG DAC 20, Exposure XIX, Mackie HR624, Exp 2010S, Arcam A75+, Dyn 42W x4, AR A-06 + Bthrm speakers.Sony HDR HC3, Nikon D70.
Car: 80Gb Ipod, AlpineIDAX001, Blaupunkt & Kenwood spk
24-07-2008, 9:35 PM
#12 (permalink)
Thanks: Gave 70, Got 57
I reckon it will be down to about £1300ish by January next year if the D300 is anything to go by, the D300 has dropped from £1300 when it first came out to about £960 now, it's dropped £100 since February this year
24-07-2008, 9:38 PM
#13 (permalink)
I will have to wait till its been out and people who own them can give good feedback.
I am heading to the states next summer so It will be about that time that I come to buy D300/700 or a D3.
Im a ideal world,I would go out and buy them all but I can so at present I will continue to shot away with my d50.
It brillant for all that I do the now and maybe by next summer I will be able to justify and use one of them too its full ability.
Flickr
24-07-2008, 10:49 PM
#14 (permalink)
Thanks: Gave 33, Got 154
Doubt it'll drop that much beachy.
D300 has droped about 25% from its RRP, the D700 RRP is 2000, so 1500 is about the lower limit for ages.
25-07-2008, 7:31 AM
#15 (permalink)
Much will depend on supply and demand. It looks like Nikon has, in the last year, sorted out their supply channels and there will be enough D700s for those willing to buy at £1999. RGB Tech are selling at £1689 already and that's where I'm buying from. Give it 3 months and I think most will be at £1650-1750 with the D3 settling at £2600 or so.
A well priced 5D II could force a lower price depending on how Canon spec it.
But let's not forget that at £2k the D700 is still £300 less than the 5D was at launch and it's a far better specced camera.
