AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Digital Cameras, Photography and Photo Editing
LinkBack Thread Tools Display Modes
Old 23-07-2008, 11:41 AM   #1 (permalink)
Thanks: Gave 1, Got 2
whats the best budget flash or macro light i should get?
just a question about whats the best budget flash or macro light i should get for macro on small insects.
is flash better than macro lights or led lights?
anyone suggest a cheaper alternative.
my current in built flash is not up to the job for macro.
also how do u guys manage to focus with extension? as i noticed my viewfinder is dark and hard to focus when useing extension tubes on small insects.
shawn is offline
Old 23-07-2008, 12:57 PM   #2 (permalink)
jomike's Avatar
Thanks: Gave 262, Got 200
Re: whats the best budget flash or macro light i should get?
Budget and macro flash are not words that go in the same sentence.
Both Canon and Sigma do dedicated macro flash units, but they are not cheap.
You could try getting a good quality torch, preferably one that allows you to focus the beam, and use that to light the subject.
I use a home made diffuser for my on board flash for macro. It works fairly well for fill light.
Extension tubes limit the amount of light entering the lens. A torch as I suggested above may help.
Mike
My flickr
jomike is online now
budget, flash, light, macro
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Macro - What ring flash? Steve N Digital Cameras, Photography and Photo Editing 2 17-04-2008 4:07 PM
DIY onboard flash diffuser for macro. jomike Digital Cameras, Photography and Photo Editing 1 24-09-2007 7:09 PM
Sigma EM140G Macro Flash imcarm Digital Cameras, Photography and Photo Editing 0 01-02-2007 12:44 PM
Flash for macro (and general use) PaulBoy Digital Cameras, Photography and Photo Editing 3 08-01-2007 5:05 PM
Panasonic 36PF10 fault - dark areas flash green, light areas flash red/pink dogcolony CRT Televisions 5 27-10-2006 1:45 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
