AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Digital Cameras, Photography and Photo Editing
LinkBack Thread Tools Display Modes
Old 23-07-2008, 11:34 AM   #1 (permalink)
Thanks: Gave 108, Got 505
most compact ultrazoom lens for travel
can anyone recommend a nice lens that has a good range of zoom for a 40D? Ideally as compact as possible when packed. is 18-200 about the sweetspot for DSLR lenses?
Doen'st need to be fabulous quality (but not hideous either). Mainly something that could be used as a second lens for on holiday, or even as a walkaround.
cheap too if possible.
50D|Canon 24-105; 85mm f1.8; 70-200f4IS; 1.4x TC|580EXII & 430EX
richard plumb is online now
Old 23-07-2008, 12:05 PM   #2 (permalink)
Thanks: Gave 219, Got 451
Re: most compact ultrazoom lens for travel
canon 55-250IS is a very nice lens. not the best build quality compared to others but the IQ is very good. also has the newer 4 stop IS. only thing is 55mm would probably not be wide enough for you if you're looking for a single lens solution
Canon 40D | Sigma 10-20 | Canon 24-105 f4L IS | Canon 55-250IS | Canon 50 1.4| 430EX | Velbon Ultra Luxi F | Kata R-103
jonnypb is offline
Old 23-07-2008, 12:19 PM   #3 (permalink)
yeah, 55 not wide enough.
also worth bearing in mind I have the 24-105, so I'm still not sure whether the convenience and extra width/reach of an 18-200 or similar is worth it, or just stick with the 24-105?
Old 23-07-2008, 12:30 PM   #4 (permalink)
denno75uk's Avatar
Thanks: Gave 142, Got 359
I can't help but think that no 18-200 will match what you already have IQ wise, but I've seen loads of photos that a friend took with the Sigma 18-200 and they were fine. He now has the Nikon 18-200VR but the Sigma can also be had with OS now. Very practical I would imagine.
James. Ignore my member status. I'm not old and know very little. I'm just very opinionated and lonely.
Canon 30D, Tamron 17-50 2.8, Canon 28-105 3.5-4.5 USM II, Sigma EX 70-200 2.8 APO DG Macro flickr
denno75uk is offline
Old 24-07-2008, 8:35 PM   #5 (permalink)
I'd quite like to hear opinions on this aswell - I've a Sony A200 and am considering the 28-200 also...
brotchaq is offline
Old 25-07-2008, 8:01 AM   #6 (permalink)
picked up a sigma 18-200 OS from LCE guildford yesterday for £250 (used). not a bad price and hopefully the convenience means I'll take it out and about more.
will probably pack the 24-105 as well, just in case
Old 25-07-2008, 7:40 PM   #7 (permalink)
Ikki's Avatar
Thanks: Gave 30, Got 59
I have had the Sigma 18-200mm for a few years now and have had great results from it, even one image published in What Digital Camera magazine. I have used it on both the KM 5D and now Sony A200 and I would recommend it as it is very compact and delivers good IQ. The OS version is a lot bigger.
The other lens to consider is the Tamron 18-250mm which has a very good performance and even longer reach. The only real downsides are that it costs more and the focusing is slow with 22 turns from close to infinity. The sigma 18-200mm lens has 10.5 turns from close to infinity and the Sony 18-250mm lens (a version of the Tamron 18-250mm lens) has about 11 turns from close to infinity.
My flickr photos.
Ikki is offline
compact, lens, travel, ultrazoom
Refbacks are On
Thread Thread Starter Forum Replies Last Post
For Sale : Velbon P-MAX Compact Travel Tripod £30 + P&P harry66 Archive : Completed Business and Expired Threads 10 28-04-2008 1:44 PM
Wanted : Compact SLR Travel Tripod devs Archive : Completed Business and Expired Threads 4 18-11-2007 5:47 PM
Cleaning compact discs & lens crowncd Hi Fi Systems and Separates 1 26-02-2007 1:22 PM
Which sub-compact with wide-angle lens? mellowout Digital Cameras, Photography and Photo Editing 7 30-01-2007 1:40 PM
WTD: Nikon D70 + Lens / Canon 70-300 Lens + 50mm Lens / Slot Loading DVD Writer DJW Archive : Completed Business and Expired Threads 14 12-05-2005 10:08 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
