04-01-2008, 2:55 PM
#1 (permalink)
Thanks: Gave 26, Got 2
Problem with 400d and Tamron Lens
I have just bought a Canon 400d and I thought I would get a cheap lens just to play.
I bought a Tamron AF55 to 200mm F/4-5.6 ld Macro. When connect this lens I sometimes get an Error - Err99.
Does anyone know what this means.
gwc
Panasonic AE700, TAG AV32R bp192 ex, Chord SPM1900, Chord SPM1200E, Chord CPA3200E, B&W Signature 805's, B&W Signature 805's (rear), B&W Signature SCM's, B&W Signature HTM1 , SVS PC Ultra, DCS Elgar+,Verdi,Purcell & Verona,Pioneer 868AVi, Lumagen HDP, X-Box, PS2, Pronto Pro TSU7000
04-01-2008, 2:59 PM
#2 (permalink)
Thanks: Gave 62, Got 103
Re: Problem with 400d and Tamron Lens
I believe its quite a common problem, this may help:
http://www.richardsnotes.org/archive...ontact-points/
Kit:
Canon 40D :: Sigma 17-70mm f/2.8-4.5 DC Macro :: Sigma 100-300mm f/4.0 EX DG IF HSM APO :: Slik Pro 400DX
04-01-2008, 3:19 PM
#3 (permalink)
Thanks: Gave 340, Got 413
And from Canon's FAQ.
Err 99: Perform either of the following actions:
1. Turn the camera off and then on again.
2. Remove the battery pack and then reinstall it.
Sony A700, HVL-F42AM flash, Sigma 24-70 EX DG Macro + 100-300 F4 EX IF APO + 1.4x EX TC, Tamron 90mm f/2.8 Di Macro, RedSnapper tripod, Pana FZ3 (for sale), Wii, Sky+, Dell Vostro 1500 flickr Darckr Jetphotos
04-01-2008, 8:09 PM
#4 (permalink)
I had tried removing the battery and the CF and leave it for twenty minutes but the problem was still there.
The Canon lens does not seem to do this just the Tamron. I have contacted the shop and they will replace.
I was just keen to know if it was a problem with Tamron lens (because if it is) there is no point in getting a replacement.
Gary
04-01-2008, 8:42 PM
#5 (permalink)
Thanks: Gave 107, Got 81
I got the same problem when I put my sigma 10-20 on my 350D for the first time I removed the lens and cleaned the contacts on the lens I've had no problem since
G5 350D 40D 17-85mmis 28-135mmis Sigma 10-20mm 18-55mm 75-300mm usm Archos 604wi-fi & Other toys
04-01-2008, 9:45 PM
#6 (permalink)
I tried cleaning the contacts with a clean (new) rubber, still no joy.
05-01-2008, 2:09 AM
#7 (permalink)
Thanks: Gave 7, Got 10
My 400d was working absolutely fine.
I purchased a Sigma 55-200mm from EBay as a "cheap & cheerful" lens.
Installed that on the 400d and the Err99 kept on appearing - not every time, but too often for me to be happy.
With mine it was definitely the contacts - I cleaned those up and I've not seen the error since.
If you've been through the 3 recognised steps to clear up the problem it could well indicate there is something more sinister going on.
05-01-2008, 5:45 AM
#8 (permalink)
Thanks: Gave 368, Got 147
On the Apperture ring on the lens itself if is there a little switch, move the switch, twist the ring to f22 ( i think) and try the lens again, I get this loads especially when swapping lenses alot,
Hth
MY FLICKR
Canon 450D/ 18-55 IS / 55-250 IS /50mm
05-01-2008, 7:49 AM
#9 (permalink)
Try cleaning them again don't use a rubber as they can leave a residue if they do they leave an insulating layer.
I just used a clean cloth and rubber the contacts
07-01-2008, 5:43 PM
#10 (permalink)
Thanks for all the suggestions.
I took the lens back today and got a replacement. It seems to have solved the problem.
07-01-2008, 5:57 PM
#11 (permalink)
Glad you managed to solve the problem, it's nice to hear some shops still look after their customers.
Kit:
