AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Digital Cameras, Photography and Photo Editing
LinkBack Thread Tools Display Modes
Old 04-01-2008, 10:09 AM   #1 (permalink)
Thanks: Gave 5, Got 3
photo and quick time help with panasonic tz3
Hi, i have just aquired a panasonic tz3 and have just taken a batch of 25 photos on normal setting . All the photos have turned out fine , but when i have uploaded them to my pc to my folder i also have a quick time symbol next to each photo . Can anyone help as to why i have quick time with each photo.Thanks
den9112 is offline
Old 04-01-2008, 10:19 AM   #2 (permalink)
pixelpixel's Avatar
Thanks: Gave 571, Got 590
Re: photo and quick time help with panasonic tz3
You have quicktime setup to view the files......
First, right click or hold down shift and right click on one of the files and you should then get 'open with'. Click on select program. Now select what you want to use.......and tick always open with.
Now open quicktime and go into preferences, go to file types and remove the image types that you don't want it to use.
:: Flickr::
Nothing like a 1000G 's - Need some help, need a 360 Bubby - See Here
pixelpixel is offline
Old 04-01-2008, 10:26 AM   #3 (permalink)
Thanks for the reply . The problem is i think with the camera settings i think as when i upload the pictures it is also uploading a quicktime movie with it .
den9112 is offline
Old 04-01-2008, 10:52 AM   #4 (permalink)
Thanks: Gave 9, Got 23
Silly question, but are you sure you took a photo, and not a video?
Have you got a .JPG file and a .MOV file? IIRC when you take a video, you also get a jpeg of the first (?) frame of the video.
My Flickr
Torpedo is offline
Old 04-01-2008, 11:01 AM   #5 (permalink)
Hi, i get the jpg file first then next to it is the blank quicktime movie file . Very annoying as i cannot seem to find how to cancel this.
den9112 is offline
Old 04-01-2008, 11:07 AM   #6 (permalink)
Thanks: Gave 32, Got 10
Are you sure that you havn't got it set on 'motion picture' setting as that produces a quicktime and a jpeg. There are several photo modes - try the simple mode, then the normal picture, then intelligent iso and see if you get the same.
Have you tried to play the quicktime file - is it a real piece of video ?
bstonehouse is offline
Old 04-01-2008, 2:10 PM   #7 (permalink)
Thanks for the help , problem sorted . i did a reset and left it alone . i must get used to reading the manuall past page one.
den9112 is offline
panasonic, photo, quick, time, tz3
Refbacks are On
Thread Thread Starter Forum Replies Last Post
1ST TIME PHOTO WITH MY TZ3 help call of duty 45 Digital Cameras, Photography and Photo Editing 8 24-11-2007 6:05 PM
Problems with quick time and Panasonic TZ3 at gig Palladio Digital Cameras, Photography and Photo Editing 0 31-10-2007 9:14 AM
Good Quick Photo Editing Software for Mac? WSB Digital Cameras, Photography and Photo Editing 6 02-04-2007 11:20 PM
Time for me to buy some photo software - what should I get? Triggaaar Digital Cameras, Photography and Photo Editing 17 16-09-2005 8:55 AM
Quick question re downsizing photo resolution pcavelle Digital Cameras, Photography and Photo Editing 4 14-11-2004 10:46 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
