Hi All,
Hope you all had a great christmas and the hangovers aren't too serious.
For those who have the lee filter holder system - could someone please measure the distances between the main screws that hold it together - ie width across holder between screw centres, and the distance between the screws on one side ? Dimensions need only be to the nearest 1 mm or so just now.
I am planning on making (
) a custom part so I can use the lee 105 mm filter adaptor on my cokin zpro system.
Essentially I want a 105mm CPL to hang off the end of the holder so I can set it easily. I don't like the idea of how the zpro CPL sits within the holder.
Any help appreciated,
Thanks,
Mark.
p.s - does anyone else use the zpro system and a CPL ?
