AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Digital Cameras, Photography and Photo Editing
LinkBack Thread Tools Display Modes
Old 24-12-2007, 10:20 AM   #1 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 471, Got 972
G9 users shoot shoot RAW: Info and help please
I use Lightroom to process my RAW files from my G9 and 5d. I have noticed that the preview of the image looks like an incamera jpeg but when I select the image to develop it goes to it's RAW white balance. Often this is insanely out. In some instances I've had to use customwb and put it to 50,000K in order to get back to close to correct colour. Can someone tell me if this is a G9 Raw file problem that happens with other software or is it Adobe's RAW processing that is not working robustly with the G9 at present. It's really annoying me now.....
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is offline
Old 24-12-2007, 10:24 AM   #2 (permalink)
Thanks: Gave 246, Got 807
Re: G9 users shoot shoot RAW: Info and help please
Are you using Lightroom v1.3? There might be some changes in that latest release. It's a fairly quick download and will install fine.
Also, on import you can select the type of preview that it generates - not sure if there are some options on that but worth a look.
Lastly, are you converting to DNG as you import? I dont - I just use "copy files to new location".
Tobers
Tobers is offline
Old 24-12-2007, 10:34 AM   #3 (permalink)
py6km's Avatar
Thanks: Gave 213, Got 100
I think that the G9 basically embeds a jpeg with the RAW data for preview purposes - I suspect that Lightroom is pulling that out to use quickly for the preview. The jpeg will look different to the RAW as you know, so I guess that's where the problem is....maybe?
50,000k sounds a bit bonkers though, so maybe there is an underlying problem as well. It's a relatively new camera; maybe they've overlooked something with their quest to try and get the D3/300 and the Leopard compatibility problems sorted?
py6km is offline
Old 24-12-2007, 12:24 PM   #4 (permalink)
pixelpixel's Avatar
Thanks: Gave 571, Got 590
What is your camera raw settings ?
Is there a raw preview option ? I don't have lightroom but bridge has a similar option to preview or you could purge the folder and get it to index your images again.
:: Flickr::
Nothing like a 1000G 's - Need some help, need a 360 Bubby - See Here
pixelpixel is offline
Old 24-12-2007, 2:48 PM   #5 (permalink)
The probelm isn't withthe indexing of the images pixel .It's with the fact you need to select white balance settings in the raw convertor that are patently incorrect....ie 50,000K......Thanks for ideas though everyone. I've downloaded latest 1.3 update and will check things out over hols
G
My Photos: Flickr
Old 24-12-2007, 4:16 PM   #6 (permalink)
You've not got some bonkers custom white balance set on the camera have you?
Tobers is offline
Old 24-12-2007, 5:35 PM   #7 (permalink)
onefivenine's Avatar
Thanks: Gave 504, Got 486
What does it do in the Canon software? Does it work?
Have adobe realeased any update - since the G9? ACR etc?
Dave
onefivenine is offline
info, raw, shoot, users
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Shoot em up maverick177uk Movies and The Cinema 32 10-02-2008 12:34 PM
Do you shoot RAW? Peakoverload Digital Cameras, Photography and Photo Editing 17 13-03-2007 11:06 PM
1D and its first shoot petrolhead Digital Cameras, Photography and Photo Editing 7 12-12-2006 9:10 AM
should i shoot in raw ?? beachy Digital Cameras, Photography and Photo Editing 13 06-11-2006 6:24 AM
Shoot the Sun SgtHowie Camcorders and Video Editing 3 06-03-2006 10:46 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
