Re: Photoshop help needed:How do I combine multiple photos?
An understanding of layers is exactly what you need.
in quick easy steps.
Open all three images. with any of them, go to "edit", "select all". Then "edit", "copy". Then "file", "new", "ok". This will create you a blank canvas the same size as your image.
If you then go, "window", "arrange", "tile horizontally", that will make it so you can see all the images at once.
Now you need the layers tab, press F7 if you can't find it. now click your first image. Drag the layer from the "layers" tab onto your blank document. Repeat this for all three.
Now click your combined document and you'll see all three layers in the layers tab. You can click the little eye icon to make the layer visible/hidden.
Click the layer at the top of the layer tab, and then choose the lasso tool from the toolbox. now roughly draw around the person in the image on the top layer that you want to keep. Then go "select", "inverse" and hit the backspace key. This will clear the background for that layer and should reveal the layer underneath.
Choose the middle layer from the layers tab, and repeat!
If you need to align any of the layers, maybe because the tripod moved very slightly, choose the layer you want to move, select the 'move' tool from the toolbox, and then use the arrow keys on your keyboard.
