Re: D40 Macro lens..
I wouldn't worry too much about the focussing issue if you mainly intend shooting macro with the lens as you will always use manual focus anyway. For insect macros, you want the longest focal length you can afford. This will give you the maximum distance from the bug to avoid scaring it. I find my Tamron 90mm is sometimes a bit limiting in this regard, and I fall back on my Sigma 70-300 APO in macro mode in these instances. I use manual focus on both when shooting macro, as well as a tripod if possible with the Sigma.
You can buy both the Tamron 90 and the Sigma 70-300 APO for about the same price as the Sigma 150, and a lot less than the Nikon 105 VR.
Mike
Mike
My flickr
Reason: Add info
