denon avr887 zone 2 volume control
Old 30-06-2009, 2:39 AM   #1
tediewest
Posts: n/a
Hello,
I have a denon avr-887 driving 2 outdoor speakers using the zone 2 functionality. What I normally do is hook my computer (iTunes) up to the front V-Aux inputs and listen outside.
My issue is that I cannot control the volume using the receiver volume control, the only thing that affects the volume is the volume control on the computer.
If I play my computer (iTunes) on the main speakers the receiver will control the volume just fine.
I do have the surround back amp set to drive zone 2 so I am not sure what is happening.
Pleas help
Thanks in advnce
- Tedie West
Old 06-07-2009, 1:18 PM   #2
Illustrious Mumbler
Mr Incredible's Avatar
19,464, Level: 33
Points: 19,464, Level: 33 Points: 19,464, Level: 33 Points: 19,464, Level: 33
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Thanks: Gave 1,655, Got 3,418
Re: denon avr887 zone 2 volume control
Do you select Zone 2 on your handset remote before tryingto adjust the volume?
Is there a setting in the Zone 2 set up which fixes the volume at a set amount? You may need to set this to variable and then try again.
Not familiar with your model, but that's what I'd be checking on mine!
HTML code is On
