04-07-2009, 2:42 AM
#1 (permalink)
| | Member
Thanks: Gave 51, Got 35 | AVR-4308A or AVR-4310???? help pls
Hello,
My 3808 gone on warranty due to sound drop out problems. I am thinking to upgrade my amp... so which one I should go for?
At there site there is no major diff b/w them.
Can any one please give me some advice.
__________________ Main: Sony KDL-52X3500, Denon AVR-3808 (Black), Panny DMP BD 35, SVS PB-13 Ultra, MA Gold GS 20/LCR/FX, Wii + Fit, Sky HD (1TB), QED HDMI-P & Profigold Optical Cables, Harmony 1000 & 785 Remote, TM-6900 1.10m Motorized system & Nikon D80 Kit 2. Bedroom: Sony 40Z5500, Sky HD, Sony BDP-S360. My HTPC |
04-07-2009, 12:37 PM
#2 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: AVR-4308A or AVR-4310???? help pls
Do you want a difference? 3 kg
I don't know that you will use the newest services...
For example: DPL IIz.
4310 has better de-interlacer (Anchor Bay). But if you want to use w-lan, it can be found only in 4308.
I think 4308 has more power. You should listen to...
05-07-2009, 3:29 PM
#3 (permalink)
| | Member
Thanks: Gave 51, Got 35 | Re: AVR-4308A or AVR-4310???? help pls
Thanks... I am not looking for wireless lan as I am using wire for my 3808 and will use wire in future for any one of them.
About 3kg I am not sure on new one they use cheap components.....
Still not sure which one to go...
05-07-2009, 6:20 PM
#4 (permalink)
| | Moderator
Thanks: Gave 13, Got 249 | Re: AVR-4308A or AVR-4310???? help pls
If in doubt go for the heavier one!
It may seem like a strange way to make a decision, but all else being equal it would suggest a beefier PSU/transformer. That ultimately is the foundation of its abilities as an amplifier. All else is bells and whistles and you have to decide if you want them.
__________________ Denon DVD-3910, Denon DVR-3805, Hitachi 32pd5200, 3x Castle Compact LCR's 2x Castle surrounds, Compact Sub Denon DVD2900, Benchmark DAC1, Cambridge Audio 840A, ProAc Response 1SC
My personal opinions are not those of the AV Forums or any other related website. |
06-07-2009, 6:16 PM
#5 (permalink)
| | New Member
4310 is cheaper more than 600 euro.
06-07-2009, 7:36 PM
#6 (permalink)
| | Member
Thanks: Gave 8, Got 1 | Re: AVR-4308A or AVR-4310???? help pls
hi
new member. any idea why i am unable to alter the dynamic eq and dynamic volume in the on screen menue on my denon 4308a amp they are both set to off but i am unable to set to on
07-07-2009, 1:43 PM
#7 (permalink)
| | Member
Thanks for your all advices... Just spoke to my dealer he said he can not get replacement to other model than 3808....
So in future for my bedroom setup I'll get 4 series and put 3808 in my bedroom.
Thanks again for your advice!
PS: I hope I will get 3808A
