Advice on fault finding a Cambridge Audio DAB300
Old 28-05-2007, 11:59 AM   #1
MikePearce
Posts: n/a
Hi all,
I recently became the owner of a faulty Cambridge Audio DAB300 (via freecycle - awesome idea).
The guy who I received it from had this to say:
> Cambridge Audio Digital Tuner DAB300 4 years old (black). Powers up OK
> but will not tune in stations properly - sounds as as though aerial not
> connected so suspect fault with internal circuitry.
My question is, how do I test this unit? I don't have anything in the way of ariels on my house - so, should I by an indoor ariel to test if it's OK? My father is an electrician and can be called upon to burn things with a soldering iron if possible, but I wanted to know if there is anything I can do to nail down the problem first.
Cheers,
Mike
Old 31-05-2007, 9:35 PM   #2
3,417, Level: 13
Points: 3,417, Level: 13 Points: 3,417, Level: 13 Points: 3,417, Level: 13
Activity: 0.2%
Activity: 0.2% Activity: 0.2% Activity: 0.2%
Thanks: Gave 2, Got 3
Re: Advice on fault finding a Cambridge Audio DAB300
On my first DAB300 S the F connector come loose and started doing that - Richer Sounds replaced it under warranty - it's not got a solid fixing - only appears to be connected via solder so if it's knocked (or in my case heavy coax cable pulled it out of line) the solder could fracture - wobbling the connector around will get a sweat spot.
Go to www.ukdigitalradio.com and put your postcode in - if you get any green stations then you are in a good signal area....
Do you have a TV aerial? If so get an adaptor from Maplin (£1.70 - http://www.maplin.co.uk/Module.aspx?...29523&doy=31m5 ) and jobs a good un....
If that works but some stations burble you may need a better aerial...
However it may be a problem I had - it tunes to stations on the lowest frequency by default so a distant multiplex may have added a new transmitter nearer his home and an autotune has screwed it up a bit....
Powered by
 Latest popular product prices
Roberts R9993
5 prices from
 £17.30 Click to show/hide the offers
Roberts Gemini R9954
3 prices from
 £27.14 Click to show/hide the offers
Pure One Mi
8 prices from
 £29.47 Click to show/hide the offers
Pure ONE Mini
4 prices from
 £39.99 Click to show/hide the offers
Roberts Classic DAB
9 prices from
 £34.84 Click to show/hide the offers
Roberts DreamTime
4 prices from
 £40.78 Click to show/hide the offers
Pure ONE Elite
4 prices from
 £66.26 Click to show/hide the offers
Roberts sportsDAB 2
6 prices from
 £62.99 Click to show/hide the offers
 Updated February 14th at 12:30am. Prices include delivery.
