| Combining FM/DAB to a diplexed signal
Hi, just a quick query about a possible installation because im not quite sure how it would work,
13 outlets, so it will require a larger sat dish, and multiswitch.
into the multiswitch will be the 4 feeds from the quadro LNB, and a feed from a TV Aerial.
The switch diplexes the 2 signals together, but how would i connect FM and DAB aerials to the system? so it comes out with a triplexed signal consisting of, DAB and FM, Satellite, and TV.
would it just be as simple as diplexing the tv aerial input to include a feed from a splitter, which has an FM and DAB aerial connected to it? then using triplexed wall plates with FM, Sat, and TV? or would it be more complicated? would the multiswitch filter out the radio signals possibly?
