I have just received a Pure Chronos CD. It sounds great and I have none of the earlier problems mentioned re FM/Dab radio. However I do have a problem with the alarms. If I have more than 1 alarm set (especially if one is set to repeat and the other not) then they do not work. I have 100% signal strength, so that is not an issue, the alarms are definately on.
For Info Alarm1, On, 0855, repeat, weekends, radio2, volume4
Alarm 2, On, 0555, repeat off, Mon, radio 2, Volume 4
Alarm 3, On, 0655, repeat on, Weekdays, radio 2, volume 4
Is anybody else having this problem or know how I can fix it?
It does appear that if I only have 1 alarm set it will work, but that defeats the object of having 4 programmable alarms!
Greg
