| Re: which dab radio for the elder?
Not any easy problem to solve from my experience. You would find it difficult to find a DAB radio with MW/LW these days. Even LW is hard to find. There are a few sets with FM/MW. Might be a good idea to look at the Roberts range. MW stations may be on the way out. If the government has its way FM will go as well, but don't panic yet.
Going for the cheapest set you can find in the Argos catalogue is probably not going to be ideal, particularly an un-branded model like this. You must also consider what the reception is like. If the person is used to a MW radio that will work anywhere/everywhere then a DAB might come as a bit of a shock unless reception is very good; almost guaranteed. I have an elderly friend who lives quite close to a transmitter but DAB only works in an upstairs room close to a windowsill, and FM is also a bit iffy. Waving aerials around for best reception is not always appreciated.
If the FM/DAB reception is going to replace something on the MW band make sure they are not going to miss anything. Radio 4 has variations between DAB/FM and what goes out on LW. Religious broadcasts and cricket come to mind.
Radio sets with dials are not generally available except small 'fiddly' cheap models. Preset buttons might be an advantage.
Battery consumption might also be an issue. If the set is to be used as a 'portable' then a DAB set might not be too welcome. MW/LW sets work for months. A DAB which might require a new set of expensive batteries every week is a different game altogether. Re-chargable batteries might be an option, but older people might not want the hassle, or forget to charge them.
Many older (and some younger) people do not realise that radio stations can be heard on Freeview, although this does not include local stations.
