Hi!
I have just recently installed a new hands free (an io play) kit into my 05 focus, however since then, the FM signal quality has been really poor, infact, so bad I cant listen to the radio!
It was fine before I installed the hands free kit, and I have not changed the head unit, so am baffled why this could be. The only difference is the amount of cabling and connectors behind the head unit. Could this be the problem? Perhaps static? I have seen a signal filter,
Here
but don't know if it will fix the problem?
You help is appreciated!
Lewis
