| Re: FM Reception
Some receivers go through succesive tuning phases if you continue to scan after the initial scan.
The 1st pass looks only for strongest signals, then weaker, then weakest.
This should be mentioned in your manual or handbook if it applies.
Failing that, find a near neighbour who has a real VHF/FM external aerial and ask if they'll let you try your receiver out on their aerial; if that still fails, then you probably have a fault or some kind of operator error.
Chris Muriel, Manchester
